Failed
Failed by beki on Thu Jun 09, 2011 11:47 am
My truck has failed it's MOT a couple months back and I made the mistake of buying a Freelander (which, 2 weeks in, blew a headgasket, took the pistons with it and now needs a new engine) So, now, after taking the bus 45 miles a day for a week while the Freelander gets a new brain I've decided to sell the damned thing and get Band back on the road. I've got a list of failures maybe some of you can shine some light on for me and possibly help me save a few quid...
Front steering rack gaiter insecure (can fix with a jubilee clip)
Front track rod end ball joint has excessive play
Front wheel bearing has excessive play
Both rear anti-roll bars have excessive play in a pin/bush...? (I can't feel it no matter how violently I thrust it)
Rear mechanical brake component has restricted free movement (mechanical brake component?? do they mean caliper?)
Brake pipe excessively chafed (i think they're making stuff up)
Centre and rear exhaust has a major leak (yes, i agree)
Nearside rear brake binding (new pads and discs are needed, maybe a caliper or two)
Brake pedal feels spongy with the vacuum fully depleted (needs bleeding after brakes put on?)
Rear brake disc in such a condition that it is seriously weakened
Front brakes imbalanced **dangerous** (which I now can feel after driving the landrover for a week... oops)
And some other things like light bulbs and brake pipe inadequately clipped (what a thing to fail but fixed now).
I strongly believe they are trying to rip me off. It seems extremely picky. I will agree with the brakes and the exhaust but some of the other things just sound stupid. So I've gone to another mechanic (who's fixing the freelander) and he'll be doing the next MOT when I fix the things I agree are wrong with it. Any input in where I can get cheap brakes for all 4 wheels and exhaust? Ebay says £113 for just the centre box... ouch.
Thanks
.All who wander are not lost.
beki
Vehicle Name: Tonka
Modifications: 99' swb,31' muds and intake system. torsion bar lifted and trooper springs.
Re: Failed by RatCav on Thu Jun 09, 2011 12:29 pm
All in all doesn't sound too bad. Fair bit of work but all can be done at home:
Easy fix then
£10 from most autofactors. About 30 mins to change. Wheel off. Soak in WD40 on the thread. Undo the retaining nut that sits on the track rod. mark on the thread where the track rod comes to with a white marker. Pop the ball joint off the hub. Unscrew counting the turns. Screw on the new one counting the turns up to the mark. Drop it into the hub. Do up the retaing nut for the ball joint. Lock it on with the retaining nut. This should keep your tracking where it was, though recommend having the tracking checked just in case.
Could just need adjusting. Worse case a couple of hours replacing both inner and outer. Good "How to" here: viewtopic.php?f=6&t=35891
Dunno about this one but get a long pry bar and give it some stick levering against something solid. That will show where the fault lies.
Does sound like caliper. Could be a simple case of whipping it off and cleaning all the sliders and re-greasing with white silicone grease. No need to disconnect the brake hose.
If the brake hoses are damaged they are a failure as they can burst leading to an enivitable conclusion. £10 most from any autofactors. Take off replace and then bleed. Hour tops.
Speaks for itself. Good place for exhausts: http://www.buypartsby.co.uk/
New pads and disks about £80. Again binding is usually to gack and grime. Take everything off and give a good clean with a wire brush. Then put all back together again with copperslip on mating surfaces and your white silicone grease for the sliders.
Probably have air in the system. Once your done fiddling with all the other brake parts take the time to fully bleed the system, starting with the rear passenger, rear drivers, front passenger, and finally front drivers side. Take care not to let the fluid level drop below the minimum mark on themaster cylinder. Bottle of fluid £10 tops.
New dis. Might as well get a new set of pads while your at it. Pain to replace. Thing to do is when your doing the wheel bearing (from before) before you take the brake caliper off get your mate to stand on the brake and undo the 6 bolts that hold the front disk onto the hub. If you look at the first picture of the guide I linked to you can see the bolts inbetween the wheel studs.
Probably due to low pads and air in the system. Basically your overhaulling the entire braking system. All the other things should eliminate this. If your going to clean all the sliders at the back. You might as well do the fronts :D
No comment needed :D
Hope this helps.
Time to do is based on how much effort you want to put into it. The more time you take cleaning everything and being careful the longer it will last and solve the issues. I would put a couple of weekends aside ... less if working in the evenings.
Price wise I would think about £200 plus the cost of the exhaust bits.
Hope this helps.
Re: Failed by RatCav on Thu Jun 09, 2011 12:32 pm
Oh and when I say mating surfaces for the copperslip I don't mean on the brake material itself ... I mean metal to metal surfaces.
Re: Failed by beki on Thu Jun 09, 2011 1:47 pm
Thanks for that. I'll start with what I can do without parts first, like taking everything off. Have to sell the mistake first before I can afford any parts. I've got the next two days off of work, so, I'll start now! :D
beki
Vehicle Name: Tonka
Re: Failed by justdan on Thu Jun 09, 2011 2:40 pm
as RatCav says it can all be done at home ............ always the cheaper option
justdan
Vehicle Name: Paddy
Alpine I.C.E system
Combra shiney nudge bar
Irmischer wheels
