Back to the Bio Diesel posting, am running 70% Bio 30% Diesel in both my 2.8 Frontera and 2l Freelander. 2.8 has been using it for over a year and covered around 9000 miles, Freelander since I purchased it back in December has done about 6000 miles on Bio. Both of them have a high milage on the clock, 165,000 on the Frontera and 145,000 on the Freelander. Freelander has IIRC the Bosch VP37 pump with elecronic fly by wire throttle similar to the 2.5 Frontera.
Both vehicles smell different, there is a slight chip shop whiff when you follow them.
I have experimented with 100% Bio in the Frontera, only noticable difference was it was slightly more difficult to start in the cold weather, Freelander is always 70/30 mix and no starting or performance issues.
Issues encountered
Frontera: During the snow I did have the odd problem with the fuel filter waxing up, wrapped the filter with loft insulation solved the problem however my new supplier puts anti-waxing agents in the Bio during cold weather
Freelander: Fuel filter clogged up after 4 months, seems to be a common problem when switching to Bio as it cleans out the tank and fuel lines, swapped filter and no further problems
Am paying 92p/litre for Bio so saving about 50p a litre, with the milage I do it works out I'm saving roughly £50- a month, doing the maths, this year I have saved £300- to date, with replacement pumps for the Freelander running at about £100- I'm already quids in
Soon to be without a Frontera after 10 years of owning one
