Frontera Technical Support • View topic - Non Fronti Help Required
Non Fronti Help Required by Riz on Fri Apr 15, 2011 9:15 pm
Evening folks i was wondering if someone can help. I have an old friend who is not into computers , web etc and is needing to change a hub on his Disco now he has ordered the Hub etc himself and it wanting to do the job himself. Now he is needing a Torque wrench which has the capability to torque up to 490NM and is wanting something which is good quality and at the same time cheap and something with some kind of warranty has to be new though. I do have a couple of guys on the forum who could help me out with this request but i thought i would put it out across the forum.
I have seen some of these wrenches at tyre fitting garages etc . He is wanting something decent as he hopes to make some money doing them for other people once he has done his own.
OWN A Fronti B 2.2i 2000
Riz
Registration Year: 2000/V
Re: Non Fronti Help Required by Drift on Fri Apr 15, 2011 9:21 pm
Try Amazon, dont laugh :lol: :wink:
I got this last year, not up to your spec requirement but shows you can get cheap quality work tools on that site.
http://www.amazon.co.uk/gp/product/B000 ... ss_product
Re: Non Fronti Help Required by BoxCleva on Fri Apr 15, 2011 9:47 pm
If he's doing his ,then going to be charging his mates, tell him to stop being a tightass and spend some money on a decent bit of kit!
Re: Non Fronti Help Required by Riz on Fri Apr 15, 2011 9:54 pm
Landi owners are tight fisted when coming to pay to get a job done :P so he want something that wont brake the bank as if people aint willing to pay he will just need it for himself and how often does a hub get changed
Riz
Re: Non Fronti Help Required by inky160 on Fri Apr 15, 2011 9:55 pm
inky160
Re: Non Fronti Help Required by Gazeddy on Fri Apr 15, 2011 10:39 pm
knuckle bar and scaff tube. 500nm is some serious torque
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: Non Fronti Help Required by Wilberforce on Sat Apr 16, 2011 8:43 pm
Aye, that's LGV wheelnut levels of torque... Does he really need that much for doing Lawn Rover hubs, etc???
Actually, on that note, it may pay him to have a word with a truck tyre fitter, and see if they can recommend something. IF he decides that a torque wrench of that spec is too expensive then if he puts the hub on himself the fitter could probably be talked into torquing it up for a few beer tokens. They're usually fairly amenable chaps if they can see a drink or three in it for em.
Re: Non Fronti Help Required by Fatbaz on Sun Apr 17, 2011 4:41 am
Hi All
For 490Nm your looking at Snap-on; Britool and the like. He'll be parting with serious money. I've done several hub bearings on Defenders; RRC's; and D1 Disco's, never needed a big torque wrench, they're just 2 nuts and a lock tab. May be he's doing D2/3 or 4's, never done them so I don't know whats fitted!!
Regards
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
