Rich that is some nasty damage still having trouble convincing my sister and her boyfriend how lucky they have been. Spoke to her today and unfortunatly shes convinced it was the right thing todo
Meooo yep it was a 05 1.6 focus and my 1st turbo change had to change the oil feed pipe. According to my local part supplier with her model focus theres a few different turbos on their system the original turbo was a mitsubishi part and the original pipes had to be changed, but other than dropping the sump amd cleaning the internals of that out i did everything else mentioned, inspected the oil filter on the last of the oil changes clean as a whistle.
I had been told that the 1.6 focus had problems with sludge collecting in the turbo oil feed and return pipes leading to the turbo failing hence the change to the original pipes.
found the offending nut stuck in the air pipe connecting the air box to the turbo but will now be keeping a very close eye on the car from now on and will be getting a very close inspection when it gets back
thanks for all the feedback on this potential disastrous situation
When I was a kid i used to pray every night for a new bicycle. Then realised God doesn't work that way, so I stole one and prayed for forgiveness
Ford Capri mk3 2.8i
1998 2.2 Dti (killed in action by an aygo)
