Magnetic Sump plugs
Magnetic Sump plugs by Big Dav on Sat Mar 05, 2011 1:55 am
British Leyland used to have magnetic sump plugs fitted to their engines - anyone fitted one to their Fronty?
Reason I'm asking is another thread has branched out to mention checking the contents of discarded engine oil to assess amount of wear. I would imagine a magnetic sump plug would be beneficial as it would remove some particles during the life of the oil.
I have heard of some people placing a magnet inside the sump pan without any fixing other than the strength of the magnet but would be worried in case it was dislodged and destroyed the engine.
Re: Magnetic Sump plugs by BoxCleva on Sat Mar 05, 2011 1:57 am
I thought the B's plug was .... or maybe I am confusing it will my old car. Memory is a bit frazzled this time of night
Re: Magnetic Sump plugs by Big Dav on Sat Mar 05, 2011 1:59 am
Maybe it is, mine is an "A" and not magnetic.
Re: Magnetic Sump plugs by Drift on Sat Mar 05, 2011 2:01 am
Yes they are a good idea, BUT good quality oil filter should negate the need for a magnetic sump plug in theory as that should filter oil it both directions, I am not sure to what miscron the oil filters work to but iron filings should definitely be caught
Re: Magnetic Sump plugs by BoxCleva on Sat Mar 05, 2011 2:03 am
Perhaps it was my multipla, but that definitely had iron filings on the plug.
Re: Magnetic Sump plugs by Drift on Sat Mar 05, 2011 2:12 am
Many do, so its frightening why we have oil filters :shock: :?
Re: Magnetic Sump plugs by BoxCleva on Sat Mar 05, 2011 2:14 am
As you say the filter obviously wasn't doing the job :? Anyway, stuff it, someone else's problem now :D
Re: Magnetic Sump plugs by Drift on Sat Mar 05, 2011 2:15 am
:lol: :lol: the true word of a problem solved :lol: love it :lol:
Re: Magnetic Sump plugs by Gazeddy on Sat Mar 05, 2011 8:40 am
i put a magnet on the end of my oil filters. makes sure i get all the filings come service time
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: Magnetic Sump plugs by jontera on Sat Mar 05, 2011 8:49 am
oh, thats clever..^
Re: Magnetic Sump plugs by Gazeddy on Sat Mar 05, 2011 9:01 am
the best magnet ive found for the job is out of a transit gearbox too
Gazeddy
Re: Magnetic Sump plugs by Big Dav on Sat Mar 05, 2011 11:10 pm
Gazzedy, I take it you just put the magnet on the outside of the oil filter?
Re: Magnetic Sump plugs by Gazeddy on Sat Mar 05, 2011 11:23 pm
yeh bit of gaffer tap holds it on then when filter change comes round magnet off onto next filter bin old filter and filings in it
Gazeddy
Re: Magnetic Sump plugs by Big Dav on Sat Mar 05, 2011 11:54 pm
Many thanks. Guess what I'll be doing!
