Astravan fuel pump relay Any ideas of where?????
Does anyone happen to know where the fuel pump relay is on a 1996 1.7D Astravan.
Regards Ady
Comment on the motor here
adyclemo
Full lenght roof rack.
Front tow bar.
CB.
Manual locking hubs.
Suspension lift.
32" BFG's
Snorkle.
Egr delete
dont think there is a relay for the fuel pump on a diesel :?
huggy
Dont look like there is, we pulled every relay and it still run. The bloody thing keeps starving of fuel.
Regards Ady
adyclemo
Front tow bar.
CB.
Suspension lift.
32" BFG's
Snorkle.
Egr delete
Check kinks in fuel lines, change filter and investigate the shut off valve (front middle on Vaux engine, somewhere at the back on Isuzu engine).
There are only 2 tools in life: Gaffa tape and WD40. If it moves and shouldn't, use the gaffa tape, if it doesn't move and should, use the WD40.
ddavidson
Vehicle Name: Stacey
Modifications: Shiny blue vacuum hoses - BF Goodrich A/T KO tyres
fuel cutoff on the isuzu is a pig to get at,you need to get under the car and remove the alloy casing under the fuel pump,the fuel pump edu is bolted to this casing,then you need to remove the sponge sound proofing thats around the pump,fuel cutoff can then be seen under the pump,also google the fuel pump edu because these are very common fault with astras,there is a company on ebay that recons these edu's,best bet would be to get the codes read,that will tell you if the fuel pump edu is at fault,another common fault with the isuzu engine is the main ecu that bolts on top of the engine,the pins on the ecu where the harness plugs into corrode and snap.
huggy
cheers guys will have a look, i know it aint the original engine, i beleive it should have the Isuzu turbo lump in it but it has a standard Vaux lump in it with the turbo hoses tied up. Bloody cowboys should be shot.
Regards Ady
adyclemo
Front tow bar.
CB.
Suspension lift.
32" BFG's
Snorkle.
Egr delete
Users browsing this forum: No registered users and 92 guests
