Frontera Technical Support • View topic - cheap mods?????
cheap mods?????
cheap mods????? by reecy on Mon Feb 07, 2011 10:13 pm
hi just got my first 4x4 1996 P reg 2.8tdi lwb looking to do a bit of green laning maybe a bit of soft off roading nothing hardcore mainly for work commute taking the tribe out etc etc. whats the cheapest mods to start out with??? cheers andy
Thanx, Andy
reecy
Vehicle Name: lean green pullin machine
Modifications: 255/65/16 road tyres on the car
and a set 235/70/15 mud terrains in the shed
removed the side steps
reverse sensors (removed)
30mm wheel spacers
Re: cheap mods????? by Trugga on Mon Feb 07, 2011 10:19 pm
Welcome to FOG.
Congratulations on the new motor - a good choice.
What condition are the tyres in - not neccessarily cheap, but a good set of AT's (All Terrain) will suit some gentle/moterate green laning and play site activity and still give a reasonable ride on the tarmac.
It's possible the the suspension may of sagged over the years - there are some "budget" methods listed in the Suspension section on how to replace the rear coil springs with something a little taller and/or stiffer and a free way to raise the front by as much as two inches.
Front and rear recovery points are a definate requirement if you intend to try out the dirt/mud and it's always polite to have you own recovery rope.
Hows that for starters ?
Re: cheap mods????? by reecy on Mon Feb 07, 2011 10:31 pm
thanx for the reply sounds good for a start. will have a look at the suspension posts now. the tyres on the car only have a couple of mill left on them. he gave me another 3 as spares not much more on them either.
Thanx, Andy
reecy
30mm wheel spacers
Re: cheap mods????? by reecy on Mon Feb 07, 2011 10:56 pm
just got a haynes manual on order aswell :)
Thanx, Andy
reecy
30mm wheel spacers
Re: cheap mods????? by fudge on Mon Feb 07, 2011 11:11 pm
well go on ebay and you can pick up a nice set of mud's/ats for about £50-60
and then look at getting the extra sus hight
Re: cheap mods????? by RatCav on Tue Feb 08, 2011 1:51 am
Wotcha buddy and by far the best choice of Frontera in my opinion.
Bargains on Ebay for tyres can be had. You have to be patient and play the bidding game. I have just picked up 5 off All Terrain tyres for £60. All had at least 8-9mm tread on them. Though that didn't include delivery/collection. Body lift for £60-70 can be done so long as you do it yourself, and suspension lift for the price of a set of rear coils. Obvioulsy all of this does entail you being good and/or confident with a set of spanners.
Re: cheap mods????? by reecy on Tue Feb 08, 2011 8:09 am
thanx. think tyres are the first thing as am going to need then anyway. then the torsion bar wind up and a set of spacers for the rear, not to sure what to do regarding the ball joint flipp :? so going to get my head stuck in the haynes manual. i did a little bit of reading up on the suspension lifts on here sounded a bit to complicated for me. :oops: maybe 1 day when iv had a bit more practice with the spanners.
Thanx, Andy
reecy
30mm wheel spacers
Re: cheap mods????? by snapper on Sun Feb 13, 2011 11:05 am
Re: cheap mods????? by Rich on Sun Feb 13, 2011 11:24 am
Ive heard Ian (bobbinsjob) is pretty cheap :D :D :D
Re: cheap mods????? by rospicer on Sun Feb 13, 2011 12:06 pm
:rotfl: :rotfl: :rotfl:
SHE MUST GET BIGGER BOOTS
rospicer
Vehicle Name: COMING SOON
Skype Username: spicechop
Re: cheap mods????? by bobbinsjob on Sun Feb 13, 2011 8:09 pm
you couldnt afford me :butt: :butt: :butt:
Re: cheap mods????? by reecy on Mon Feb 14, 2011 9:47 pm
Thanx, Andy
reecy
30mm wheel spacers
Re: cheap mods????? by furball on Mon Feb 14, 2011 10:15 pm
I wouldn't worry about flipping the ball joints if you're only going to lift it a couple of inches.
Also, you can get a permanent sump drain from difflock that will make oil changes easier and cleaner.
furball
Re: cheap mods????? by Drift on Mon Feb 14, 2011 10:41 pm
2" Lift may require a BJ flip Chris, it all dependant on the individual vehicle :wink:
Re: cheap mods????? by reecy on Mon Feb 14, 2011 10:46 pm
only going to lift it 2inch. if i dont flip them will it affect anything????
Thanx, Andy
reecy
30mm wheel spacers
Re: cheap mods????? by Drift on Mon Feb 14, 2011 10:48 pm
Its possible your camber could be affected and cause tyre wear, you may get away with it, but you can pop down the M58 to Kirkby I can take a look :wink: and you might even meet the one and only Andysd1 :shock: :lol:
Re: cheap mods????? by reecy on Mon Feb 14, 2011 11:07 pm
Thanx, Andy
reecy
30mm wheel spacers
Re: cheap mods????? by Drift on Mon Feb 14, 2011 11:17 pm
Aha the East Lancs :wink: :lol:
No probs, let me know and we can sort it out :D
Re: cheap mods????? by snapper on Tue Feb 15, 2011 10:30 pm
Re: cheap mods????? by furball on Fri Feb 18, 2011 10:31 pm
furball
Users browsing this forum: Facebook [Linkcheck] and 88 guests
