Frontera Technical Support • View topic - Anyone used Slick50 ?
Anyone used Slick50 ? by Big Dav on Tue Feb 01, 2011 12:18 pm
About to do engine oil change and was going to add Slick50 but wondering if there are any benefits. Anyone used it? Was it any good?
Re: Anyone used Slick50 ? by snapper on Wed Feb 02, 2011 2:20 am
Yep I put the stuff in all my cars as soon as I get them, seems to do what it says on the tin and apart from killing the Turbo on the fronty yesterday I've had no problems. The wifes wee MX5 is probably only still going because of the stuff, in the past she wasent that good at checking the oil and it's got a wee low a few times, like off the dipstick low.
You do have to 'top' it up once/twice a year though. And I havent tried it in the final drives yet.
Re: Anyone used Slick50 ? by Big Dav on Wed Feb 02, 2011 1:01 pm
Thanks snapper, think I will give it a go, see if I can preserve my motor for a while. :drink:
Re: Anyone used Slick50 ? by 4x4 bobby on Wed Feb 02, 2011 1:10 pm
You are right snapper good stuff ive used it in mine!
Re: Anyone used Slick50 ? by Big Dav on Wed Feb 02, 2011 1:21 pm
Thanks guys, you've made my mind up for me. :drink:
Re: Anyone used Slick50 ? by Drift on Wed Feb 02, 2011 1:55 pm
I dont generally use additives but tested the water with molyslip a few years ago, my mind was made up when coming home from a days laning in Wales Tim Bumptj was in his 2.8 and dropped all his oil and didnt know untill he got home, and that was with a motorway journey (god knows when he lost the oil) he checked it and it was empty but the engine ran well, he had used molyslip in his oil, he refilled the oil and ran for another year or so with no problems before selling it and that was about three years ago and the car is running fine now.
Re: Anyone used Slick50 ? by Big Dav on Wed Feb 02, 2011 2:09 pm
Makes you wonder why manufacturers don't use similar additives either when car is assembled or recommend addding it after engine has bedded in. Thereagain, repairs might decrease but purchasers looking for reliability would certainly be interested.
Re: Anyone used Slick50 ? by Drift on Wed Feb 02, 2011 2:14 pm
I believe the molilibium (or something) found in molyslip is used in the aircraft industry, not sure if its true.
Re: Anyone used Slick50 ? by snapper on Wed Feb 02, 2011 8:52 pm
Re: Anyone used Slick50 ? by rospicer on Wed Feb 02, 2011 9:02 pm
Used the stuff in 2 different cars and found it works wonders, Going to throw it into mine on the next oil change as well.
SHE MUST GET BIGGER BOOTS
rospicer
Vehicle Name: COMING SOON
Skype Username: spicechop
Re: Anyone used Slick50 ? by Drift on Wed Feb 02, 2011 9:04 pm
It didnt show for some reason or it was just on the very limit, Tim is never one to slack on the car, so it was a bit strange to say the least. :shock:
Re: Anyone used Slick50 ? by fynn on Wed Feb 02, 2011 9:26 pm
super stuff,would highly recomend it.
the autobox stuff is a godsend for hard shifting
use it and sit back and relax! :dance:
fynn
Registration Year: 1994/M
Vehicle Name: stumpy
Re: Anyone used Slick50 ? by Drift on Wed Feb 02, 2011 9:29 pm
Do not use gearbox oil additive in a Frontera as our cars use engine oil in the gearbox and gearbox oil additive is not compatible.
Re: Anyone used Slick50 ? by snapper on Wed Feb 02, 2011 10:18 pm
Re: Anyone used Slick50 ? by Drift on Wed Feb 02, 2011 10:27 pm
:lol: :lol: I like it :lol: :lol:
Re: Anyone used Slick50 ? by Big Dav on Wed Feb 02, 2011 10:45 pm
Re: Anyone used Slick50 ? by jimmybhoy on Wed Feb 02, 2011 11:36 pm
jimmybhoy
Registration Year: 2004/04
Re: Anyone used Slick50 ? by Drift on Wed Feb 02, 2011 11:44 pm
I will have to check on the auto box as the rickety old A series I am used to didnt have autos :oops: :lol:
It very likely depends on the product at what temperature it works, I know some cheap products are like an oil thickener and come out like syrup, these tend to quiet and engine down short term but soon thin out, molyslip is very fluid but I have not looked into the temperature properties.
Though all that said if you have decent quality engine oil in your manual box you will be fine without an additive as said it doesnt get as hot as the engine and it does not suffer from carbon build up like in an engine so lasts considerably longer and does not need filtering.
Re: Anyone used Slick50 ? by Hound Dog on Thu Feb 03, 2011 12:13 am
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Re: Anyone used Slick50 ? by Drift on Thu Feb 03, 2011 12:39 am
And there you have it :lol:
Users browsing this forum: No registered users and 92 guests
