Frontera Technical Support • View topic - 3.2 V6
3.2 V6
3.2 V6 by coyote on Mon Jan 31, 2011 9:09 pm
Hi ya, excellent forum for a newbie. Thinking of buying a 3.2 V6. What bad bits do i look for? How many miles per gallon do they do?
Thanks
coyote
Re: 3.2 V6 by andysd1 on Mon Jan 31, 2011 10:41 pm
some good info in this section, just make she has a good service history, and around 19 to 21mpg
Re: 3.2 V6 by rospicer on Mon Jan 31, 2011 10:57 pm
Like Andy sais, check for a good service history, They are pretty much bullet proof mechanically. The main prob's I've encountered are overheating issues related to the viscous fan and offen they get vacume leaks around the common chamber. Other than that I've had no probs at all with mine...
Good luck with your search pal :D
SHE MUST GET BIGGER BOOTS
rospicer
Vehicle Name: COMING SOON
Skype Username: spicechop
Re: 3.2 V6 by coyote on Tue Feb 01, 2011 6:58 pm
Thanks. How often do the cam belts need changing & how much is it?
coyote
Re: 3.2 V6 by andysd1 on Tue Feb 01, 2011 7:51 pm
think its 25k to 30k, i do mine at 20k
Re: 3.2 V6 by rospicer on Tue Feb 01, 2011 9:37 pm
Price wise for the cambelt you're looking at loads if you go to Vauxhall for the parts. Everything is sold seperately and are expensive, and 9 times out of 10 the cant even get them any more. Your best bet is to look on ebay US and check for the kit for a 6VD1 engine code for isuzu Rodeo. Thats if its the earlier V6 till 2001 you looking at getting. Not sure what the engine code is for the later models.
I managed to get a belt for 7 quid on ebay but I'll be scouring ebay.com for the rest (adjusters and idler pulleys) for the next few months. Hopefully someone on here might know of a local supplier which isn't too expensive :)
rospicer
Re: 3.2 V6 by andysd1 on Tue Feb 01, 2011 11:23 pm
Re: 3.2 V6 by Drift on Tue Feb 01, 2011 11:40 pm
Have you tried Isuzu?
Re: 3.2 V6 by andysd1 on Tue Feb 01, 2011 11:59 pm
Re: 3.2 V6 by rospicer on Wed Feb 02, 2011 8:26 pm
how do you rekon this looks? http://cgi.ebay.com/ebaymotors/98-04-IS ... ccessories
Dont think its that bad and it comes with a new water pump as well 8)
rospicer
Users browsing this forum: Facebook [Linkcheck] and 88 guests
