Frontera Technical Support • View topic - Is it normal ????
Is it normal ????
Is it normal ???? by cav on Fri Jan 28, 2011 9:00 pm
Hi guys just want to know is it normal for the back end of a 3.2 V6 to kick out on the back end alot ? Im asking as mine seems to be more of a drift truck than anything else hahahah. Ive tryed the same bends etc at low speeds and its the same. Is it a noraml thing or im i driving it wrong..... never had a rwd before. I will have to try leaving it in the highest gear i can :?
Rolling in my TANK
cav
Vehicle Name: TANK
Re: Is it normal ???? by fogman on Fri Jan 28, 2011 9:36 pm
i would think at normal driving speeds all frontys should handle pretty much the same so i would say no its not normal, my old 2.2 lwb handles & corners well considering its an old bus
Re: Is it normal ???? by cav on Fri Jan 28, 2011 9:56 pm
May have to look at the back end on sunday then. I just thought i was driving it wrong. I set off to work around 5 am and nowadays its always cold and abit of frost and i thought that was the problem but when i come home about 5 pm and the ground is dry it still kicks the back end out :?
Rolling in my TANK
cav
Vehicle Name: TANK
Re: Is it normal ???? by Drift on Fri Jan 28, 2011 10:05 pm
Check your shockers and tyre pressures, they are the usual cause :wink:
Re: Is it normal ???? by john (smifffy) on Fri Jan 28, 2011 10:05 pm
could be your tyres i had it on my 2.4 changed tyres to different brand and tread pattern
it stuck to road like chit off a shovel :D :drink:
Re: Is it normal ???? by BoxCleva on Fri Jan 28, 2011 10:07 pm
mis matched tyres on the back can also cause this. I test drove another Fronty before I bought mine and the ar$e end was all over the shop and that had one AT and one road tyre on the back :?
Re: Is it normal ???? by cav on Fri Jan 28, 2011 10:12 pm
thanks guys will have a look at the tyers tomorrow and let you know
Rolling in my TANK
cav
Vehicle Name: TANK
Re: Is it normal ???? by lwbant on Sat Jan 29, 2011 7:54 am
dont know how to post vids on here but there is an awesome one of an opel fronty drifting round a roundabout on youtube!
practice and you could start enjoying it lol!unfortunately mine hasnt quite got the grunt :cry:
lwbant
Modifications: +2" discovery rear springs
front wound up 8turns
flipped upper balljoints
front driving lights
4 light roof bar
Re: Is it normal ???? by andysd1 on Sat Jan 29, 2011 8:11 am
i think its just you cav, i think you have developed what all us v6 drivers get, a lead foot, but if its that heavy yet, check previous posts
Re: Is it normal ???? by BoxCleva on Sat Jan 29, 2011 9:40 am
Re: Is it normal ???? by lwbant on Sun Jan 30, 2011 8:27 am
thats the fella! how much fun does that look? :D
lwbant
4 light roof bar
My Drift truck problem again by cav on Sun Feb 06, 2011 7:06 pm
Right guys this is a follow on from my last post here >>>>> viewtopic.php?f=32&t=40496&p=436326#p436326
Ive checked the shockers, tyres and tyre pressures and all is fine. Now ive just been looking at the Vauxhalls Frontera owners manual and on page 101 on the right of the right hand page it says " DRIVE RANGES, four wheel drive- high range (4H) For greatest traction on WET, ice or snow covered roads " and this has got me thinking as when the "TANK" has its drifting problem its always wet so should i have it in 4x4 high in the wet or will i kill it ?
Rolling in my TANK
cav
Vehicle Name: TANK
Re: My Drift truck problem again by BoxCleva on Sun Feb 06, 2011 7:45 pm
Re: My Drift truck problem again by andysd1 on Sun Feb 06, 2011 7:48 pm
you will kill it, as the modern tyre will grip just as good in the wet as the dry,
Re: My Drift truck problem again by cav on Sun Feb 06, 2011 7:53 pm
Thanks for the replys guys.
The tyres i have are good year wrangler hp 245/70/r16
Rolling in my TANK
cav
Vehicle Name: TANK
Re: My Drift truck problem again by cav on Sun Feb 06, 2011 8:02 pm
Forgot to say the tyres are also like new
Rolling in my TANK
cav
Vehicle Name: TANK
Re: My Drift truck problem again by rod 2.4 on Sun Feb 06, 2011 8:41 pm
some tyres must rotate in a certin direction there should be a marker on them to show which way they should be run. i had a set fitted on a opel manta once and it started to drift the back end out in the wet so i thought wow these new tyres are cr#p but when i had a look at them they had been fitted back to front. [ left tyre was on the right hand side and vice versa ] so they where rotating the wrong way it was like driving on slicks. :wink:
my 3.1 fly's by the 3.0's like there ther sitting still. coz the most of them are.
rod 2.4
Vehicle Name: tonka
Modifications: 3.1 td isuzu trooper [ the fronty's big brother]
body lifted 1.5 inch's
33 mud tyres
pro comp +2 0n the front and the torsion bar's wound up to match
custom front crossmember and bumper with winch mounts
big sound system
Region: Northern Ireland
Re: Is it normal ???? by huggy on Mon Feb 07, 2011 9:14 am
im on goodyear wranlgers 255/65/16 and they grip very well in the wet,i have to try to make the back end step out,wranglers are also none directional tyres so they cant be on the wrong way :wink: i think its just the fact youve not driven a rear wheel drive car,i tried to explain this to the wife but she said rubbish its the same,then one day she came home white as a ghost :D just dont put your foot down until she is straight :)
huggy
Re: Is it normal ???? by fogman on Mon Feb 07, 2011 2:32 pm
i would think that you would have to give a std fronty a fair amount of stick to get the back end out in dry conditions, mine with 31 tyres & a 2" lift in the wet is still quite sure footed, in fact ive never had the back step out yet but that might be to my advanced years now , my old 2.3 cortina spent most of its time sideways on corners & roundabouts etc so its not like im a drifting virgin :D
Re: Is it normal ???? by cav on Mon Feb 07, 2011 5:10 pm
I must be a drift car racer then :lol:
Rolling in my TANK
cav
Vehicle Name: TANK
Users browsing this forum: Facebook [Linkcheck] and 88 guests
