Frontera Technical Support • View topic - '93 Polo oil light
'93 Polo oil light
'93 Polo oil light by furball on Sat Jan 22, 2011 1:27 pm
Not sure if this is the right bit but here we go anyway.
One of the bosses at work has a '93 1.0 Polo with an oil light that stays on all the time. I'm assuming it'll be something like the oil pressure sensor? If so, where would it be hiding?
furball
Re: '93 Polo oil light by ddavidson on Sat Jan 22, 2011 6:36 pm
I believe on one this age it's near the oil filter housing (you'll see a connector plug nearby).
There are only 2 tools in life: Gaffa tape and WD40. If it moves and shouldn't, use the gaffa tape, if it doesn't move and should, use the WD40.
ddavidson
Vehicle Name: Stacey
Modifications: Shiny blue vacuum hoses - BF Goodrich A/T KO tyres
Re: '93 Polo oil light by lurchy666 on Sat Jan 22, 2011 8:37 pm
on a 93 should be on top of oil filter housing as said, my golf had 2 sensors on it, a hi pressure warning and a low pressure warning sensor so take the sensor along with youu if you need a new one so you get the right one,
just brought 2.5 tds lwb
lurchy666
Modifications: no mods so far
Re: '93 Polo oil light by Drift on Sat Jan 22, 2011 9:32 pm
They are a bugger for the oil light staying on, I ran one for 20k with the light on, all that was in one summer mind :lol:
Re: '93 Polo oil light by inky160 on Sat Jan 22, 2011 10:25 pm
chances are it not the sensor very rare for the vw sensor to go i would say it mor like the oil pump is on it way out as it a common prob with them :(
inky160
Re: '93 Polo oil light by furball on Sat Jan 22, 2011 11:45 pm
furball
Users browsing this forum: Facebook [Linkcheck] and 96 guests
