Frontera Technical Support • View topic - 2.8TD
2.8TD
2.8TD by lyndbo on Wed Dec 29, 2010 3:17 pm
HI GUYS,looking on fleebay came across a 2.8td,n reg,£495,apparently won't rev over 2000rpm,any ideas what it could be,could be interested,they've been told could be a turbo pipe fault.Item number: 320636189739
is it worth persuing?
lyndbo
Re: 2.8TD by Drift on Wed Dec 29, 2010 3:24 pm
Looks like maxxis mudders tyres, It could have a turbo pipe off or air in the fuel system (more likely) and just need bleeding, usually just by using the hand pump/primer on the fuel filter, could just even need a fuel filter.
Re: 2.8TD by lyndbo on Wed Dec 29, 2010 3:40 pm
could it be a good buy?
lyndbo
Re: 2.8TD by Drift on Wed Dec 29, 2010 4:31 pm
As with anything like that you are taking a gamble, one question, have you checked the MOT online or get the seller to check it online as you need the number from the log book, that will tell you how long is left on it and what it last failed on.
But if you want it, its a good buy as they have shot through the roof recently in the bad weather.
Re: 2.8TD by lyndbo on Wed Dec 29, 2010 5:17 pm
had a reply off seller,smokes when you rev it hard and theres a smell of unburnt fuel.
lyndbo
Re: 2.8TD by Drift on Wed Dec 29, 2010 5:34 pm
What colour is the smoke? and rev hard, is that up to the 2000revs?
It could be return fuel pipe blocked from the pump.
Re: 2.8TD by ddavidson on Wed Dec 29, 2010 5:44 pm
There are only 2 tools in life: Gaffa tape and WD40. If it moves and shouldn't, use the gaffa tape, if it doesn't move and should, use the WD40.
ddavidson
Vehicle Name: Stacey
Modifications: Shiny blue vacuum hoses - BF Goodrich A/T KO tyres
Re: 2.8TD by woodwizzard on Wed Dec 29, 2010 6:23 pm
Got to be worth a punt at that money. If it was on my doorstep I would have it. It can be heard running and you can drive it about to make sure the drivetrain is sound. Could be a simple fix, maybe a blocked particle filter in the exhaust system etc. 2 muds on the left and 2 ATs on the right is a strange combo, one set per axle would be better.
Re: 2.8TD by ddavidson on Sat Jan 01, 2011 9:40 am
ddavidson
Re: 2.8TD by RatCav on Sat Jan 01, 2011 1:21 pm
I would say thats more than likely to be the actual turbo itself giving out. Thats what happened to mine just before it blew completely.
Re: 2.8TD by keneth on Sat Jan 01, 2011 2:18 pm
keneth
Vehicle Name: The Mule
Re: 2.8TD by RatCav on Sat Jan 01, 2011 3:38 pm
Good thing is you can do a direct swap with any 3.1 Trooper as well for the turbo so not a big issue to replace. Good time to replace the exhaust manifold bolts that have gone missing over the years as well. All in all if you know what your doing can be fixed inside a day and if you have all the bits needed.
Re: 2.8TD by woodwizzard on Sat Jan 01, 2011 6:26 pm
Been sold now. Someone has picked up a good deal, even if only sold on in parts. Looked a generaly clean car.
Users browsing this forum: No registered users and 52 guests
