Snow Driving
Snow Driving by th4neuk on Tue Nov 23, 2010 11:27 pm
Hi Guys,
Sorry to ask a noddy question :oops: but can I use the 4wd system on the b series on snow without it buggering up the axles even if on the road. Obviously once the snow goes and you hit norma tarmac it's easy to switch it off but don't want to bugger up me axles. It never snowed when I had my last one and it looks like we are going to get some and living out in the wilds now so to speak I'm guessing the roads won't get treated out here??
Ta
Alan
Alan
th4neuk
Sidesteps
Rear privacy glass stuff
Tweaked torsion bar
BFG AT's
Extra reversing lights
Wish List
Rear Spring +2"
+2" Shocks
Re: Snow Driving by andysd1 on Tue Nov 23, 2010 11:33 pm
yes, you can use it on snowy roads, but as soon as you hit the gripy stuff again switch it back
Re: Snow Driving by Drift on Tue Nov 23, 2010 11:35 pm
Your fine in snow, even patchy snow as long as the tarmac patches are not to regular or large and the road is slippy so as to release the wind up in the axle.
Have a look at this on the FOG Wiki 8)
Re: Snow Driving by th4neuk on Tue Nov 23, 2010 11:50 pm
Thanks guys,
I thought that might be the case but I'm really enjoying the car at the moment and don't want to break it from being a pudding.
Ta
Alan
Alan
th4neuk
Sidesteps
Tweaked torsion bar
BFG AT's
Wish List
Rear Spring +2"
+2" Shocks
Re: Snow Driving by Drift on Tue Nov 23, 2010 11:59 pm
If you feel the steering pulling slightly or feeling tight that is wind up and you should switch back to 2wd as soon as possible :wink:
We all have to asked, to be honest the bumf VX send out with the car (A series especially) is very vague :wink:
Re: Snow Driving by fred on Wed Nov 24, 2010 1:10 am
hi all,
another quick snow question.
if your pulling out to a gritted road from snow and been in 4wd, is it ok to just put it in 2wd and go without reversing to unlock the hubs? just thinking about if someones behind and reversing aint an option. would this stop any wind up?
cheers. :)
fred
Registration Year: 1994/M
Modifications: swb...
16" pajero alloys with insa turbo special tracks on.
rear window tints.
suspension & 3" body lift.
snorkel.
bullbar extended.
petrol tank lifted higher.
30mm wheel spacers.
3 point harnesses
Re: Snow Driving by gregster on Wed Nov 24, 2010 1:31 am
No probs with not unlucking your hubs Fred...in fact I would deliberately leave them locked as it will go back into 4wd when you are going then without stopping (but you are not really supposed to do that though!)
Re: Snow Driving by Drift on Wed Nov 24, 2010 10:28 am
I have driven hundreds of miles with the hubs locked and if the conditions warrant it I would advise keeping them locked for the convenience, that goes with auto hubs and manual hubs on the A series.
Re: Snow Driving by fred on Wed Nov 24, 2010 3:08 pm
cheers for the info guys, just need the snow now. :)
fred
rear window tints.
snorkel.
bullbar extended.
30mm wheel spacers.
3 point harnesses
Re: Snow Driving by Lee_R on Wed Nov 24, 2010 9:09 pm
Evening all.
Just wanted to pick up on Greg's point about selecting 4wd on the move. Can I just check my understanding (or lack there of) by asking for your comments on how I think the 4wd system on an A works:
- Whilst moving without the front hubs engaged, the front diff and hence prop shaft will be stationary (or as good as) regardless of the speed of the road wheels. Thus would trying to engage 4wd on the move will result in accelerating the whole lot up to speed very quickly, hence potentially getting a nice crunchy soundtrack and causing damage?
- With the front hubs locked but in 2wd the front diff and thus prop shaft should be turning at a similar rate to the rear, just not being driven by the transfer box, but rather by the wheels. So if this is the case, then in theory you should be able to move in and out of 4wd at reasonable speeds without causing too much trouble?
Cheers, and sorry to waffle on. I just like to try and understand the mechanics behind what's going on...
Lee
Lee_R
Registration Year: 1992/K
New rear leaf springs
Wheels refurbished
Re: Snow Driving by Drift on Wed Nov 24, 2010 9:18 pm
Assuming you have auto hubs, they will not lock until you select 4wd (from stationary) if however you deselect 4wd and do not unlock the hub by reversing (or leave manual hubs locked) the drive train (front prop and diff and driveshafts) will not rotate with power from the gearbox/transfer box but the wheels will be locked in dragging these components, it will not damage them.
You can not change into 4wd at speed on the A series, you can at very low speed with a bit of practice but if you get it wrong you will pay the price with the loud crunch and gearbox complaining :lol:
