Frontera Technical Support • View topic - Seen This?
Seen This?
Seen This? by Paul A on Wed Nov 17, 2010 5:48 pm
Lovely but pricey.....
Bet it's great with that big ol' 3 litre diesel!
And T.O.D!....... why didn't Vauxhall do that!!!!!!
http://cgi.ebay.co.uk/Isuzu-Wizard-3-0- ... 588b05a9c9
V6 Isuzu Vehicross
Paul A
Re: Seen This? by Drift on Wed Nov 17, 2010 5:53 pm
Im not sure but if those 30L are the same as the Trooper 30L, which I suspect they are going by the car's age then they tend to blow up with serious injector problems, there was a huge recall on them.
Re: Seen This? by bigdazz on Wed Nov 17, 2010 5:55 pm
yes ste u are right had a few in Australia mines stopped using them
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: Seen This? by BoxCleva on Wed Nov 17, 2010 6:01 pm
Looked great going through the pics until I got to the interior pics :sick:
Re: Seen This? by RatCav on Wed Nov 17, 2010 7:37 pm
It uses the Izusu Vehicross Torque on demand system. Also the Isuzu Trooper 3.0 TD. There was a massive recall on the engine to have the injector sleeves (and a few other things addressed) They are still offering a free recall on the sleeve upgrade. The issue was the sleeves had two o'rings on them. The o'rings were meant to keep the oil, fuel and coolant seperate, however they originally under spec'd the tolerances and after a while gaps would open and allow fuel into the oil, causing issues as you can guess. The engine itself is great, once you have had the work done on it though. Lots of power and torque, however if you are trhinking of buying it I would get the VIN and contact Isuzu and get them to check wether its had the recall work done or not.
Re: Seen This? by Paul A on Wed Nov 17, 2010 7:51 pm
V6 Isuzu Vehicross
Paul A
