Frontera Technical Support • View topic - Flexi induction pipe
Flexi induction pipe by BoxCleva on Thu Nov 04, 2010 10:01 pm
HI folks,
I need some flexi induction pipe to run from my air box to raise the air intake level for when I'm wading. Something that looks something a bit like this I guess http://cgi.ebay.co.uk/Flexi-Induction-C ... 2708wt_907
I've no idea if that is the right diameter I need, I will measure it tomorrow, but what I could do with knowing is where i might get some tomorrow ? Is it a car spares place ? Building supplies ? Any ideas where I could get some 'off the shelf' ?
Re: Flexi induction pipe by Drift on Thu Nov 04, 2010 10:08 pm
65mm or at a push 75mm should do it.
This is good stuff, and remember sealant and to block the drain hole in the bottom of your air box.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
And for ref, my contraption :lol:
Re: Flexi induction pipe by BoxCleva on Thu Nov 04, 2010 10:19 pm
Re: Flexi induction pipe by Drift on Thu Nov 04, 2010 10:23 pm
Ahhaa ermmm a strong possibility taking into account your location is an agricultural supplier?
Re: Flexi induction pipe by BoxCleva on Thu Nov 04, 2010 10:30 pm
Re: Flexi induction pipe by Drift on Thu Nov 04, 2010 10:33 pm
Dunno, had a hell of a job thinking what it was called when I tried getting some, kept finding rubbish pond hoses.
Re: Flexi induction pipe by BoxCleva on Thu Nov 04, 2010 10:36 pm
Re: Flexi induction pipe by Drift on Thu Nov 04, 2010 10:40 pm
Re: Flexi induction pipe by BoxCleva on Thu Nov 04, 2010 10:45 pm
Yikes, £65 for 5m roll. I hope the local bods sell it by the metre :shock:
Just one more point , am I better to bend the open end near the bulkhead down ? (rather than up)
Re: Flexi induction pipe by Drift on Thu Nov 04, 2010 11:04 pm
I have mine as level as I can, the turbo will suck anything passing in anyway, dont be tempted to put your hand on the end and rev the engine, it will fold like a concertina in a mili second and dissapear :lol: :lol:
So we know you will try it :lol:
Use zip ties to secure it in place and any areas you think it may possibly chaff just lop a big load of duct tape around it.
Oh, a metre is more than enough :wink:
Re: Flexi induction pipe by BoxCleva on Thu Nov 04, 2010 11:07 pm
Re: Flexi induction pipe by Drift on Thu Nov 04, 2010 11:11 pm
Cant remember the set up in yours, do you have an engine bay piccy :D
Re: Flexi induction pipe by BoxCleva on Thu Nov 04, 2010 11:13 pm
Re: Flexi induction pipe by Drift on Thu Nov 04, 2010 11:19 pm
Red would be the way to go, or green if the pipe will fit (doubt it) but keep the entrance to the hose back from the bulkhead to allow any water over the bonnet to drain down without hitting the hose entrance.
Red is preferable as it points away from any splashes.
Re: Flexi induction pipe by BoxCleva on Thu Nov 04, 2010 11:22 pm
Nice one, cheers Ste. Just gotta find some pipe tomorrow and I'm away :D
Re: Flexi induction pipe by Alfie on Sat Nov 06, 2010 10:43 am
if you are struggling to find some I have some 65 mm heat proof steel wire reinforced flexy pipe. I can pop you some in the post if you need. I supplied some to mrtom last weekend and he seemed happy with it. :D
Vehicle Name: Dino
Re: Flexi induction pipe by glynn969 on Sat Nov 06, 2010 10:51 am
i seem to remember getting some from machine mart ...it was listed as heavy duty pump drainage hose or something along those lines ...i used it on the old vec as a cold air feed from the lower bumper
glynn969
Vehicle Name: Red Monster
headlight protectors
steinmetz grille
pipercross induction kit
safari snorkel
FOG stickers
braided brake hoses
Skype Username: glynn969
Re: Flexi induction pipe by BoxCleva on Sat Nov 06, 2010 11:22 am
Re: Flexi induction pipe by andysd1 on Sat Nov 06, 2010 12:26 pm
i used this, as i found it sits on the cone filter,
http://cgi.ebay.co.uk/80mm-3-3-16-Cold- ... 20b03a9cc0
