Frontera Technical Support • View topic - Failed mot
Failed mot
Failed mot by N1ova on Fri Oct 29, 2010 11:22 am
Just been for my mot and it failed.Exhaust leak at flexi pipe,brake efficiency 44%.And the other problem is faulty cam sensor.
Exhaust is an easy fix,but any ideas on how to sort the brakes?its had new pads all round.And its going to cost a fortune to fix :( :?
N1ova
Vehicle Name: Blue flash
Re: Failed mot by Rifleman on Fri Oct 29, 2010 11:52 am
When were the pads fitted mate?
It could be that they havent bedded in yet.
If you fitted them just before the MOT, thats probably the problem.
It takes a wee bit of time for them to deglaze and form the shape of the discs, if the discs are used ones.
Going by the vibes from you, he hasnt failed on any specific side, so no brake pulls etc.
So brakes must be balanced correctly. Sounds like the friction surfaces.
Did you do the pads yourself? Were the sliding pins on the calipers lubricated?
Re: Failed mot by N1ova on Fri Oct 29, 2010 12:06 pm
Cheers rifleman pads were fitted bout 8 months ago,the brakes didnt pull just failed on efficiency,i lubed up the sliders with copper grease.I havent a clue when the brake fluid last got changed,would this make a difference?Cheers Adrian.And to top it all of the exhaust flexi pipe is not seperate from the centre box as the mot man stated. :x
N1ova
Re: Failed mot by fogman on Fri Oct 29, 2010 12:12 pm
sorry to hear she failed mate, you can buy flexi pipes from ebay etc & have it welded on to both parts of the original pipe, i had to change mine last year cos the flexi was falling to bits but if its too far gone a whole centre section is available from millners
http://www.milneroffroad.com/categories.asp?cID=11479
Re: Failed mot by N1ova on Fri Oct 29, 2010 12:30 pm
Did you buy yours off milners fogman?And what was the quality of the part like?
N1ova
Re: Failed mot by fogman on Fri Oct 29, 2010 12:35 pm
Re: Failed mot by Frenchfarmer on Fri Oct 29, 2010 5:22 pm
Sounds like you need to change the fluid in the brake system and see how that helps.
A few quids worth of fluid and the right brake bleeding kit can do wonders.
Is the pedal a bit soft.
Frenchfarmer
It works!!!!
Re: Failed mot by N1ova on Fri Oct 29, 2010 6:23 pm
The exhaust flexi on mine was seperate from the centre box.It had a little pin hole in it so i had it welded,it only cost me £10.Just hopeing a fluid change and a general celan up of the brakes sorts the brake problems out. :D
N1ova
Re: Failed mot by bigdazz on Fri Oct 29, 2010 8:45 pm
fingers crossed mate
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: Failed mot by RatCav on Fri Oct 29, 2010 8:59 pm
It would pay to put new fluid in, and bleed bleed bleed them. Just start with the one that has the longest pipe from the master cylinder, then the next furthest and so on. Once your done repeat it to make sure your getting all the old fluid out. Keep an eye on the level in the reservoir and make sure it doesn't drop below minimum or you will draw air into it.
As for the cam sensor its an easy fix (especially on a Frontera) though I am surprised it came up on the MOT or am I reading it wrong.
