Frontera Technical Support • View topic - 4WD help
4WD help
4WD help by stu bags on Thu Oct 28, 2010 9:57 pm
HI Guys
Looking at buying a fronty it's a 2.2 dti ltd W reg
My question is it's got a problem with the 4WD the seller say's (4x4 works inconsistently - I believe this is due to 4WD ECU needing replacement)
can anyone tell me if it sounds right and how much would it cost.
Thanks
Stu
stu bags
Re: 4WD help by Drift on Thu Oct 28, 2010 9:58 pm
Very very likely leaking vac pipes.
Re: 4WD help by stu bags on Thu Oct 28, 2010 10:03 pm
Thanks for that wil try and go to look at it now l have some idea what to look for.
thanks again for the very quick reply.
Any idea what MPG l would be looking at
Stu
stu bags
Re: 4WD help by Drift on Thu Oct 28, 2010 10:12 pm
Check the ends of the pipes in the vac system as they corrode and split, you might get away with cutting the ends off and refitting.
Most say around 33mpg but a dti owner will be able to verify that for me.
Re: 4WD help by stu bags on Thu Oct 28, 2010 10:14 pm
Thats good enough for me. Will see what happens
Stu
stu bags
Re: 4WD help by BoxCleva on Thu Oct 28, 2010 10:16 pm
Re: 4WD help by wiltshire-medic on Fri Oct 29, 2010 12:52 pm
MPG for mine is average 33-34. But then i tend to drive like a granny! When i absolutely cane it when ita used as a working van i got 31.
AIR GOES IN AND OUT
BLOOD GOES ROUND AND ROUND
ANY DEVIATION IS A PROBLEM
wiltshire-medic
Modifications: Its marked up as an Ambulance, Silver and Green reflective chequer banding round the sides, Red and Yellow chevrons to the rear.
Tinted rear third windows. LED's everywhere, Siren, Headlight flashers.
Proper chunky tires all round.
Re: 4WD help by SPEEDBIRD 202 on Fri Oct 29, 2010 2:22 pm
Hi there stu bags
as above for the fuel - burn figures and sometimes better :)
If you don't have any luck getting the 4 wheel drive to work, let us know as there are some other areas that might cause this - and we will try and help you :soap box:
Good luck
SPEEDBIRD 202
Re: 4WD help by duncs on Fri Oct 29, 2010 4:34 pm
Heh - its me thats selling that fronty - its not the vac pipes as I did those a while ago. Here is more info on my diagnosing of the 4wd problem
viewtopic.php?f=7&t=35877
Duncs
duncs
Vehicle Name: Tank
