Frontera Technical Support • View topic - engine swop
engine swop
engine swop by ben wallace on Thu Oct 28, 2010 11:29 am
i have a 2.2 16v lwb transglobe from 98 .Its starting to knock should i flog it or swop the engine? If i do swop the engine do i swop it with one exactly the same or do i have options Cheers Ben
ben wallace
Model: 2.2i Transglobe 5dr
Modifications: urm :-)
Re: engine swop by jammywagonwheel on Thu Oct 28, 2010 12:28 pm
had the same, turned out it was a big end gone (on its way out), rebuild cost was about £400 for a complete overhaul (rings valves etc) + my time. Essentially I now have a brand new engine...
John..
You cant polish a t*rd..
if its broken - fix it
if it isnt - mod it!
jammywagonwheel
Organic Modifications
Vehicle Name: Martha Farquah
Modifications: #1 - Martha
passed MOT,
new front pads & calipers
Broke it
Bled,
Sworn,
Cried,
Hit it with hammers
Fixed it
Re: engine swop by FUDDY MUCKER on Thu Oct 28, 2010 1:10 pm
As these engines are quite hard to come by in a good condition, a second hand one is possibly a no no.
So I would consider flogging it if you dont want to go down the rebuild option.
Unfortunately, these where the worst engine fitted to the frontera's, possible the worst engine vauxhall ever made.
They are prone to bottom end wear and even chucking conrods though the side of the block !!!!
Re: engine swop by ben wallace on Thu Oct 28, 2010 1:36 pm
bugger!! such a shame , it pulls like a train at the moment its only at 2400rpm when warm you can tell something doesn't sound right . still not sure what to do :|
ben wallace
Re: engine swop by hobsey on Thu Oct 28, 2010 2:01 pm
hobsey
Vehicle Name: Fanny
Modifications: Air freshener
HD Trooper rear coils
2" coil spacers
265/75/16 Fedima Frontieras
Recovery shackle
Magnamount Aerial
Re: engine swop by ben wallace on Thu Oct 28, 2010 2:09 pm
ben wallace
Re: engine swop by ben wallace on Thu Oct 28, 2010 2:10 pm
maybe i'll ask for advice on the landrover forum, they may not slate my engine so much :lol:
ben wallace
Re: engine swop by MG Autos (Mark) on Thu Oct 28, 2010 2:19 pm
A lot of the 2.2's issue's tend to stem from premeture componant failure. :shock: The oil pump is a notorius week spot and has probably worn and is no longer doing it's job properly which has probably contributed to your bottom end knock.
The majority of the 2.2's issues can be avoided if you change the Oil & Water Pumps every 3-4 yrs along with the Cam Belt and make sure that anti freeze / coolant is drained, flushed & refilled every 2yrs. Some times spending a few quid on additional maintenance can save you big bucks further down the road....
MG Autos (Mark)
Member & Trader
Registration Year: 1994/M
Re: engine swop by fogman on Thu Oct 28, 2010 2:23 pm
im not sure the engines that bad but after talking to mechanics etc they believe the problems could be caused by vx fitting the lump so its slightly tilted towards the rear end in a fronty rather than dead flat as it was probably designed to be used.
in the nearly 2 years ive been a member of fog ive noticed that the majority of times when a head gasket fails which they often do in the 2.2 its normally the rear end cylinder that goes so there must be something in it :|
Re: engine swop by Kevin1964 on Thu Oct 28, 2010 3:17 pm
Kevin1964
