what to do
what to do by joncal on Mon Aug 30, 2010 2:55 pm
Not sure what to do with my 2.3 td fronty ive started to put it back together , and now have other projects to do , the fronty / just replaced the rear poly bush set /one sides on ,the other still waiting as i havent finished with the fuel tank yet ,made a new peice for the fuel filler neck / had the fuel tank off to check it all which is in situ but not connected back up due to the fuel pipes need replacing which ive made new ones , but not put them on yet , got 2 tyres for the back but havent changed them yet , and the sump needs replacing as it has a small fracture where the sump plug leaks , and it needs a mot , my heads telling me to get rid as i need the room , but prior to me starting to replenish stuff on there it ran perfect, engine can be seen running but for a limited time as the diesel tank is disconected , if i get enough interest i could strip it or sell as a whole unit v5 present , what ya think :D
joncal
Re: what to do by andysd1 on Mon Aug 30, 2010 3:05 pm
how much you lookng for, send me a pm if you want
