Frontera Technical Support • View topic - MoT hitches?
MoT hitches?
MoT hitches? by FronteraGirl on Tue Aug 24, 2010 9:11 am
I still haven't fixed or replaced the dash on my truck, and it suddenly occured to me that it's MoT time soon. Will the fact that the rev counter, speedo, fuel and temp gauges don't work, mean that its an instant failure?
FronteraGirl
Re: MoT hitches? by SPEEDBIRD 202 on Tue Aug 24, 2010 3:27 pm
You bet it needs those things -- Look At This
SPEEDBIRD 202
Re: MoT hitches? by john boy on Tue Aug 24, 2010 6:54 pm
No so long as the abs light works as it should and the mileage can be read the rest is not part of the mot :wink:
Re: MoT hitches? by jpbiketransport on Sun Aug 29, 2010 12:46 am
Hi You should be fine for the mot as long as the abs light does not stay on it will be fine, also the handbrake warning light needs to come on and go off correctly, the speedo, ect is not checked at mot,
jpbiketransport
Vehicle Name: yeep
Re: MoT hitches? by Wilberforce on Sun Aug 29, 2010 8:33 pm
I'll attest to that...
Lara passed her last MOT with no speedo cable, cos I'd dropped a gearbox on it and crushed it. Everything else worked though, but if the speedo isn't checked, then I fail to see how it could fail for temp, fuel or rev gauges.
Re: MoT hitches? by jpbiketransport on Sun Aug 29, 2010 8:44 pm
Ive just had a word with a mot tester friend, the only thing testable on the dash board is the abs light [ the light just cant be on] other then that it can not fail if nothing works. [i was wrong about the handbreak light] Only thing is a diesel smoke test should be done at operating tempreture and the only way a tester can tell is by the tempreture guage so the tester will have to ask you if its ok to do a smoke test, just say yes and all will be fine. hope this is of some help John
jpbiketransport
Vehicle Name: yeep
Re: MoT hitches? by FronteraGirl on Sun Aug 29, 2010 10:46 pm
Thanks guys, should be ok then. Just need to find the old cert to see when it's due! :shock:
FronteraGirl
Re: MoT hitches? by mad mechanic on Mon Aug 30, 2010 8:30 pm
mad mechanic
