wally confesions
wally confesions by lwbant on Wed Aug 18, 2010 6:52 am
changed coolant temp sensor the other day then car ran like bag of poo untill i realised i had soaked the coil pack! what a wally!! :oops:
posted this in 2.2 and i think rifleman just about beat me with his confession (trying to drive off with back wheels jacked up!) :oh yer:
so give us all a giggle with your blonde moment confessions!
lwbant
Modifications: +2" discovery rear springs
front wound up 8turns
flipped upper balljoints
front driving lights
4 light roof bar
Re: wally confesions by jammywagonwheel on Wed Aug 18, 2010 8:56 am
erm.. none - ever - Fronty drivers dont make schoolboy errors..
theres's a "Friend" :oops: however that helped change a starter motor on a Clio (French car :axe: ), put new one in, tried to start the car and nothing - dead, the owner was in the car turning the key - nothing, not a click - whirr - nada.
Took 'knackered' unit back to the autofactors who tested it, nothing wrong - took it back - refitted it and spotted that "someone" hadnt reconnected the battery :oops:
John
You cant polish a t*rd..
if its broken - fix it
if it isnt - mod it!
jammywagonwheel
Organic Modifications
Vehicle Name: Martha Farquah
Modifications: #1 - Martha
passed MOT,
new front pads & calipers
Broke it
Bled,
Sworn,
Cried,
Hit it with hammers
Fixed it
Re: wally confesions by FUDDY MUCKER on Wed Aug 18, 2010 10:52 am
I once decided to do a pick up conversion, named "MUD MUNCHA" (use search button), it had an LPG conversion fitted.
Now it was'nt road legal, so there was no petrol in it, just LPG, so whilst I was working on it in the drive every few days I would fire it up and leave it ticking over for a whilem to keep the battery charged.
Anyway, one day it just died, and would start come hell or high water.
So been as I had an identical 2.0 ltr sport at the side of it that run like a dream, I decided to start to swap over the companants that cuase it to not start, one by one.
MAF, Crank Sensor, Throttle Postion sensor, dizzy cap, rotor arm, coil pack, etc, etc. with each one changed I tried to start it, Still no joy, after several hours changing things over I gave up, and swapped everything back.
Did a code read on the ECU, just came up with the usual fault, code 32, cranksensor low voltage, which is normal if the engine not running.
Left if for a few days, went back out, fingers crossed, tried to start it, still no bloodly joy !!!
Any way, by chance, ALEX, was popping over that day, so I thought 2 heads are better than one, i'll get him to have a look.
He arrived, popped the kettle on, told him my problems and what was his first reaction ..............
Has it go gas in ????
Well at this point, a very large penny dropped as ALEX went to the rear of the truck and proceded to shake a VERY EMPTY Lpg Tank, then points out the guage telling you how much gas is in the tank, was, yes you guessed it ..........
SHOWING RED, EMPTY !!!!
Moral of this story, I'm a Numpty, and should always check the simpliest things first !!! :oops: :oops: :oops: :oh yer: :oh yer:
Re: wally confesions by BoxCleva on Wed Aug 18, 2010 8:05 pm
Went away for a few days camping last week, so decided I'd better make sure I had jack/wheelbrace etc etc ect. Looked in manual and wheel brace and winder for the jack should be behind a panel in the boot. Guess what ? No bloody wheel brace or jack winder. Reluctantly had to take my trolly jack / breaker bar and socket in an already over loaded car. Was only on the final day when I was reading the manual whilst eating a bag of chips by the seaside that the bits I was missing were actually under the rear seat on a LWB and I had been reading the 3 door section of my manual :axe: :axe: :axe:
Re: wally confesions by jontera on Thu Aug 19, 2010 10:34 am
not a fronty one but..
after fixing headgasket on a saxo, new plugs, etc..darn thing wouldn't start..sounded like it wanted to fire, so half a can of easy start still no joy..oh maybe I'll recheck the timing and the plug gaps..can't be the ignition leads as it's a coil pack thingymejob...all done...still no joy...oh i know fuel!!has to be that....nope loads of fuel..
3hours later after checking all the fuses consulting the web...guess who hadn't pluged the coil pack back into the loom?....twice!! plug back in a away it went first turn..
Re: wally confesions by Krusher on Thu Aug 19, 2010 11:45 am
Was at work last night at about 11.30 in a shopping centre in Maidstone when I had to go down to the loading bays to get some equipment
from the van. To get to the loading bays you have to go down 3 floors in a lift, these lifts are the industrial type where you have to close the
outer and inner door yourself. Anyway I got what I needed from the van and made my way back to the lift with armfuls of stuff. I got back in the
lift and closed the doors and pressed the button, nothing! So I thought maybe the doors werent closed properly, so I opened and closed them again.
Still nothing, so I put down all the stuff I was carrying and gave the doors a really hard slam shut and only then did I realise that I was pressing
the button for the floor I was already on.... :oh yer: :oh yer: :oh yer: :oops: :lol: :lol:
Re: wally confesions by Stuart69 on Thu Aug 19, 2010 12:57 pm
When I got my Fronty I noticed I only had locking nuts on the back wheels. After a couple of months I remembered about it and bought a new set of lock nuts as I didn't have key to remove the old ones.
I spent a couple of days removing one of the old lock nuts. It was a nightmare due the the depth of the hole in the alloy, I tried drilling, chiselling, Dremelling, shouting, swearing and staring at it very hard and eventually got it off. I had wrecked the stud though.
I sat down for a well deserved coffee and a smoke and went to get a lighter from the door pocket. It was there I found the locking key socket thingy I had put in there when I first got the car so I didn't lose it, I'd forgotten all about it :oops: :roll: :rotfl:
I've still to replace that stud someday :)
Stuart69
Re: wally confesions by Norse on Thu Aug 19, 2010 1:17 pm
just the usuals here, wondered why car wouldnt start......hadnt plugged in battery, leaving stuff under car then driving over themand silly as hell thing slike that nothing serious yet :P
IT support/Advice just ask me
Norse
+2" Sus Lift
+2" Body Lift
DIY Snorkle
Shedload of stickers
To do
Boot Organiser construction
Remove spare wheel holder
Perhaps a CB
Re: wally confessions by andysd1 on Thu Aug 19, 2010 7:35 pm
none fronty,
got in to work early, because i did not fuel the wagon the night before, anyhoos, gets the wagon ready drives out the yard, heads towards my patch for the day, parks up near the cafe, where i meet the lads, gets my self a coffee and switchers in to relaxing mode, now i am thinking no lads, doh they are still in the yard, i had spoken to them before i left the yard,
