Frontera Technical Support • View topic - Big Mans MPG test
Big Mans MPG test
Big Mans MPG test by bigman1207 on Sun Aug 08, 2010 8:53 pm
just giving that new shell unleaded a go and seeing how it works on an everyday basis.
OK this is the way im doing it....not mega technical at all and more of seeing how far I can stretch the £20 top up a time.
Petrol light illuminated. Add £20 fuel. Reset trip....drive until fuel light comes on. I do know that it is no way an exact science but its keeping me happy as I drive mainly at 2500 rpm in 5th. I only use my truck for work and sad as I am travel the same route day in day out so driving style and road should be consistant.
£20 Total @114.9 ltr = 102 Miles
£20 Shell @114.9ltr = In progress.
Car - 1993 Sport 2.0 petrol. Current Milage circ 95k, serviced last month. Tyre pressure all at 32 psi.
When I get the result of the Shell I have read up on adding acetone to the fuel. 2.5ml to 1 Ltr of petrol (1.5ml to litre of diesel) and see how that gets on.
cheers bm
bigman1207
Modifications: Totally Standard
Re: Big Mans MPG test by alex on Sun Aug 08, 2010 9:16 pm
Ive found adding some milners petrol additive did stretch the mpg, also the shell stuff helped. None made it more than break even though, just longer between stops.
Re: Big Mans MPG test by Road Hog on Sun Aug 08, 2010 9:23 pm
Seem to think Doris was trying the acetone thing in his 2.2i,never did hear the outcome of that experiment :?
Re: Big Mans MPG test by drinksoptional on Sun Aug 08, 2010 10:50 pm
what was average speed
Re: Big Mans MPG test by jammywagonwheel on Mon Aug 09, 2010 9:59 am
Ive used the acetone trick on my old flatbadge (shoehorned a 302ci V8 into it and it kept breaking) and for the MOT on Martha, works a treat.
I use 1ml per litre of fuel, it helps vapourisation of the fuel by lowering the surface tension and therefore you get a finer spray and a better / cleaner burn.
Words of warning though..
1) DO NOT use nail varnish remover - only use 100% Acetone (you can get it from a pharmacist)
2) It bu@@ers up plastics, turns them white, easiest way is to add x litres of fuel to your tank, then use a 1 litre bottle and mix the acetone with a bit if fuel (1 drop per litre) give it a shake then add to fuel.
3) There is apparently degradation caused to hoses etc, but in such minute quantities it is minimal.
4) Doesnt make any difference to fuel consumption, if it does its tiny, BUT the engine - both times - ran smoother and pulled a bit better.
5) AVGAS (aviation fuel - 94UL - High Octane) gives a much better burn - mix it 1 part AVGAS : 4 parts Pump fuel, find a friendly chap who works at a local airport who drinks in your local pub :wink: , and it costs around a pint per 5 litres :mrgreen: also Kerosene works a treat for cleaning engines / greasy bits.
Have fun!
John
You cant polish a t*rd..
if its broken - fix it
if it isnt - mod it!
jammywagonwheel
Organic Modifications
Vehicle Name: Martha Farquah
Modifications: #1 - Martha
passed MOT,
new front pads & calipers
Broke it
Bled,
Sworn,
Cried,
Hit it with hammers
Fixed it
Re: Big Mans MPG test by Dave Tucker on Mon Aug 09, 2010 2:08 pm
I have been keeping a close eye on Monty now for a few months. Most of the driving I do is urban and I'm getting 24.1 mpg. Not bad for a V6 :mrgreen:
FRONTERAS ARE NOT FOR SCHOOL RUNS
Dave Tucker
Vehicle Name: Monty
Modifications: 3" Suspension Lift, Trooper +2 Coils, 2" Body Lift, Gas Shocks, Jap 16" Alloys with 32" Tyres, Modded Front Arches, Flipped BJ's, Lightened Flywheel, K & N Filter, S/S exhaust, Ken Lowe Electric Fan, HID Xenon Bulbs, Drilled & Grooved Brake Discs, Red Dot Pads, Lightened Fully Wax Oiled Body, Modified Front Diff Hangers and Rear Bump Stops, Removed Spare Wheel and Modified Rear Door and Bumper, Underbody Reversing LED's, 100w Hella Spots, DRL's, Sony Bluetooth.
Re: Big Mans MPG test by bigman1207 on Mon Aug 09, 2010 3:05 pm
sourced the acetone and will use it as described jammywagonwheel (cheers) once i have posted the results of the shell fuel. Will be adding it to shell fuel i think.
oh and as above re average speed...... I drive at a smidgen under 2500rpm which in fifth equates to around 52mph on dual carridgeway on unrestricted roads, other speed limits are kept to with highest gear suitable.
BM
bigman1207
Re: Big Mans MPG test by bigman1207 on Thu Aug 12, 2010 10:20 am
Shell @114.9 just done 119 miles
now have £20 of Shell with 2.5ml per ltr of acetone added.
immediate impressions..... a lot smoother more responsive and slightly previoys irratic idle noticably better.
cheers bm
bigman1207
Re: Big Mans MPG test by jammywagonwheel on Thu Aug 12, 2010 12:01 pm
jammywagonwheel
passed MOT,
Broke it
Bled,
Sworn,
Cried,
Hit it with hammers
Fixed it
Re: Big Mans MPG test by bigman1207 on Thu Aug 12, 2010 6:42 pm
Cheers John, will cut back to 1.5ml per litre for the next text then down to 1.0ml after that to see how it goes.
Oh I mix it in a petrol can with approx 500 ml and funnel it in straight after refueling at the petrol stn
bigman1207
Re: Big Mans MPG test by jammywagonwheel on Fri Aug 13, 2010 8:02 am
jammywagonwheel
passed MOT,
Broke it
Bled,
Sworn,
Cried,
Hit it with hammers
Fixed it
Re: Big Mans MPG test by bigman1207 on Fri Aug 13, 2010 9:23 am
LOL i meat i mix the acetone up with half litre of petrol !
Yeah got my syringes as felt like a addict asking for them at the surgery!!! also gave me steri strips and cooking spoons !!! apparently they come in a pack! lol.
Off to the pound shop later so will invest in a new funnel, and for some strange random reason i want a metal mess tin!
Oh also while on subject of pound shop, the 151 red oxide and metal paint is really good stuff!! dont know if its been started but how about a value thread showing whats good at the good old pound shop.
Will check my plugs after a couple of weeks kinda keen on using this stuff well until I have used up the rest of the litre I bought!! lol
bigman1207
Re: Big Mans MPG test by jammywagonwheel on Fri Aug 13, 2010 12:34 pm
ohh-got me thinking.. just about to do a tip run (taken day off to get garden sorted out in peace & quiet) and theres a Poundland just opened in Fleet...
Theres a thread on here called 'National Bargain Corner' in "the lounge", theres loads of good bits in there, there was a toolbox from Argos, tow ropes in tesco's (51p)etc.
Keep us posted on the Acetone, pretty sure it does bu@@er all for consumption, the engine runs a bit sweeter, and cleans up the engine a treat..
got a beer festival tomorrow :drink: :drink: :party: :drink: :confused:
South East Picnic Sunday... (Maidstone - Kent if your passing - see http://www.fronteraowners.co.uk/forums/viewforum.php?f=63)
I'll see how Martha behaves with my "Secret ingredient" in the tank (AVGAS - Plane Fuel :wink: ) last of it going in today.. hee hee
John
jammywagonwheel
passed MOT,
Broke it
Bled,
Sworn,
Cried,
Hit it with hammers
Fixed it
Re: Big Mans MPG test by bigman1207 on Mon Aug 16, 2010 10:38 am
Shell £20 @114.9ltr + 2.5ml Acetone = 122 Miles
Not an exact science mind ya!!
NExt test will be £20 of shell with 1.5ml Acetone
bigman1207
Re: Big Mans MPG test by jammywagonwheel on Sat Aug 21, 2010 8:08 am
:shock:
Last edited by jammywagonwheel on Sat Aug 21, 2010 8:11 am, edited 1 time in total.
jammywagonwheel
passed MOT,
Broke it
Bled,
Sworn,
Cried,
Hit it with hammers
Fixed it
Re: Big Mans MPG test by jammywagonwheel on Sat Aug 21, 2010 8:09 am
:shock:
Just been reading back on this.. - Saturday morning, house all quiet, "How Its Made" on Discovery Channel - SWMBO sleeping off our meal out last night, junior at a friends house..
102 - 122 miles..
Thats nearly a 20% increase..
I know its as you say - "not an exact science" - but that a big leap!
Keep us posted...
John
jammywagonwheel
passed MOT,
Broke it
Bled,
Sworn,
Cried,
Hit it with hammers
Fixed it
Re: Big Mans MPG test by Dave Tucker on Wed Dec 12, 2012 3:45 pm
I now use shell with 1.5ml Acetone also. My V6 is returning 24.8. I'm happy with that. But it would be nice to hit 25 :D
Dave Tucker
Vehicle Name: Monty
