Frontera Technical Support • View topic - how far has yours gone ?
how far has yours gone ? by zaqlow on Mon Aug 02, 2010 1:21 pm
My new 95-96 2.8tdi swb fronty has done just over 160,000 MILES but the engine doesn't smoke apart from a little short puff on 1st startup, it pulls well and is pretty tidyand starts 1st time every time so far! :D
It does seem a big improvment on my oler 2.3tdi with 40,000 less miles.she smoked :oops: and was a pig to start :oops:
But my question is what is the maximum miles you have seen on the 2.8 in mile please ?
I know its down to regular oil service's but thought it would be interesting to see/hear :dance:
[size=50]I Think I might Be Confused Bro, But I'm Not Sure [/size]
zaqlow
Vehicle Name: HACKER
Modifications: 265x75r16 grizzly claws
off set wheels
front bumper trim
rear bumper removed
1x range rover horn :)
lift planned soon
Re: how far has yours gone ? by BadBoy on Mon Aug 02, 2010 1:44 pm
Mine's on 142000 and runs sweet as a nut (when it's not broke :lol: )
Skype Username: paul.bush21
Re: how far has yours gone ? by Frenchfarmer on Mon Aug 02, 2010 4:02 pm
148,000 Which, considering she has spent three years in a barn and 1&1/2 Years sitting here seems quite high.
That's almost half it's life not being used.
Frenchfarmer
It works!!!!
Re: how far has yours gone ? by zaqlow on Mon Aug 02, 2010 6:16 pm
I'm winning at the moment then with 160k yea lets celebrate :drink:
zaqlow
off set wheels
front bumper trim
rear bumper removed
lift planned soon
Re: how far has yours gone ? by Frenchfarmer on Mon Aug 02, 2010 6:23 pm
Frenchfarmer
It works!!!!
Re: how far has yours gone ? by awdriver96 on Tue Aug 03, 2010 12:59 pm
I know of a couple of 2.8s with much higher mileage one in a fronty has done 260k and another in a landrover conversion ( farmer owner low maintainance!!!! ) has done 450k plus, so your only grasshoppers you lot :lol:
Mike
Reason: Tidied a bit
Frontera Lwb 2.5 tds (The powerful ! one )
awdriver96
Technical Co ordinator
Re: how far has yours gone ? by damrabbit on Tue Aug 03, 2010 2:42 pm
For the record mines done a mere 105,000 barely run in really :lol:
,32mm wheel spacers
1997 BMW 328i Touring(DEAD)
1993 gas guzzling monster ?
Re: how far has yours gone ? by Frenchfarmer on Wed Aug 04, 2010 5:50 pm
Once had a 1 Million mile party in a purple London Cab that we used as a breakdown wagon, and that was back in 1975.
Frenchfarmer
It works!!!!
Re: how far has yours gone ? by zaqlow on Thu Aug 05, 2010 2:34 am
zaqlow
off set wheels
front bumper trim
rear bumper removed
lift planned soon
Re: how far has yours gone ? by awdriver96 on Thu Aug 05, 2010 9:46 am
At that time it was still the BMC / BL 2.5 straight 4 diesel engine ( worked on those as apprentice and later) and I would bet it had at least 5 engines and or rebuilds in that mileage, even though as a cab they tended to run 20 hrs a day with driver changes and so were under fairly ideal conditions. To illustrate this, there was cab company inlondon with a 63/4 Vauxhall Cresta ( straight six 2.5lt engine) used as a cab ( private hire would guess) and with proper oil changes ( 3k and 6k with filter in those days) it had done somewhere around 650k miles without any major work which for that era was amazing, but again 24 hr use with driver changes. Another was a Housing development a bit later ( 70s) where all the flats were supplied in each block by a petrol driven generator, using the Hillman Hunter 1725cc 4 cyl petrol engine to power it ( Oh the days of cheap petrol ) this ran 24/7/365 except for short times off for servicing and oil/filter changes, in this case the absolutely perfect conditions for any engine. When they were taken out and mains elec fully used, they estimated the engines ( 7 off if I remember rightly) had done the equivalent of over a million miles each.
It shows that which Castrol always put in their ads, the most wear on an engine is the first few minutes of running.
All interesting stuff :D
Mike
awdriver96
Re: how far has yours gone ? by Road Hog on Thu Aug 05, 2010 11:03 am
Re: how far has yours gone ? by awdriver96 on Thu Aug 05, 2010 11:45 am
As for prizes I think over 7 million is tops for now :lol:
Mike
Cant have accolades going to France even for an ex Pat :lol:
awdriver96
Re: how far has yours gone ? by Gillien on Mon Sep 13, 2010 5:59 pm
Mines an "N" reg with currently 184,300 miles and still going
Gillien
Modifications: No mods as such except for larger than standard greenway off road tyres ( and a little cutting back on the wheel arch plastics) yet to make our minds up as to lift the body or not and do the lift business on the suspension
Re: how far has yours gone ? by Llywelyn111 on Fri Sep 17, 2010 7:26 pm
Mines 1996 P reg and has done 102k
Llywelyn111
Re: how far has yours gone ? by RatCav on Fri Sep 17, 2010 9:03 pm
155,000 km there abouts in 20 years on the Trooper. I have only done about 5000 km of those. Loving it.
Re: how far has yours gone ? by Frenchfarmer on Fri Sep 17, 2010 11:01 pm
Frenchfarmer
It works!!!!
Re: how far has yours gone ? by RatCav on Sat Sep 18, 2010 10:30 am
Harder and harder to find. I think the engine will outlasst the truck to be honest ... mind if it does go we all have the option of dumping in the 3.1 Trooper engine instead. Direct fit if you get the earlier mechanical fuel pump version.
Re: how far has yours gone ? by James Bass on Sat Sep 18, 2010 12:35 pm
Well mine is practically brand new then. On my way to work an hour ago, the odometer read 077770. 8)
Re: how far has yours gone ? by transporter on Sat Sep 18, 2010 7:15 pm
mines 6 years old with 127000 on the clock when it works
transporter
Registration Year: 2004/53
Vehicle Name: barbie3
Re: how far has yours gone ? by andytats on Sat Sep 18, 2010 10:17 pm
mine was 102017miles in nov 09 now its 113807
