Frontera Technical Support • View topic - what should i do?
what should i do?
what should i do? by maxlee on Fri Jul 16, 2010 9:48 pm
help guys and girls
i see a frontera sport tonight on the side of the road for sale so i thought it would be rude not to stop and have a look so i then found out its a 2.8td sport 8)
but it has covered 198k miles and has a vibrashion from 15mph up sounds like a tractor but i think they all do don't they? its moted till martch next year and i can have it for around 500 is it worth it i still have my 2L sport.
i don't want to buy it to find the vibrashion costs more then the fronty to fix :roll:
i don't know what to do is it worth the cash???
would be grate full for your input
maxlee
Vehicle Name: ffs what now
Re: what should i do? by Drift on Fri Jul 16, 2010 9:57 pm
What tax or MOT does it have.
We need more info on the vibration and they do sound loud compared to a 20l but the car could be in need of an oil change and tappets setting, this will make a huge difference, if its started from cold then yes they are very noisy till warmed a bit.
How is the body work? is there any history, cam belts, clutch and the like?
Re: what should i do? by maxlee on Fri Jul 16, 2010 10:04 pm
hi drift was started from cold the oil press gage was right at the top, but the bloke did say it needed a oil change soon i didn't ask about history but he didn't seam like the type of person not to keep it having his brother own a garage or sum thing he said.its had 3 tyres and brake pipes for mot in martch / may
its hard to explane the vibrashion it feels like a turning type of one if that makes sence :oops: mot is till march or may next year but no tax also has a chip in windscreen
is the running gear etc good for lots more miles then 198k?
maxlee
Re: what should i do? by Drift on Fri Jul 16, 2010 10:11 pm
At that mileage most things should have been replaced so very likely good.
Keep oil changes to every 3000 and filter ever 6000 it should run a lot longer.
I have heard of the 4jb1 doing well over 300000.
Re: what should i do? by maxlee on Fri Jul 16, 2010 10:15 pm
worth taking the chance and buying then??
are the 2L props etc the same? i was thinking if i got it werther or not i could swap bits over to try and find the problem maybe??
sorry for all the questions bit unsure as i am not swimming in cash but alwas regretted selling my old 2.8td before i even got to use it :(
maxlee
Re: what should i do? by Drift on Fri Jul 16, 2010 10:20 pm
No the props will be different as the gear box is different to length is not the same.
I would love to say buy it but I honestly couldnt with out seeing it, think you have to check out the vibration.
It could be a worn UJ or wheel bearing, even a bent wheel.
If its like a rumble it will be a wheel bearing.
Get a good drive and warm it up, then offer £400 :wink:
Re: what should i do? by bigdazz on Fri Jul 16, 2010 10:23 pm
get the reg and i will reg check it for u
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: what should i do? by maxlee on Fri Jul 16, 2010 10:29 pm
i tryed the 400 atact and he's not having none of it :oops: i thought turning up in my nova would have shown i didn't have that much moneys :lol:
oooooooooooooooooooooooooooh i don't know what to do i should have thought about it more when i was there and took a picture or to to show you guys :oops:
its this colour
oh its on a p reg as well lecy windows
dazz thats a kind offer thank you but i haven't :cry:
maxlee
Re: what should i do? by BadBoy on Fri Jul 16, 2010 10:30 pm
Engine alone should go for over £400 on eBay if you bought it and found it has a major problem with the running gear, as the landy guys seen to like the Isuzu 2.8
Skype Username: paul.bush21
Re: what should i do? by Drift on Fri Jul 16, 2010 10:31 pm
£450 if you can figure the vibration, he wont get more than that for it :wink:
Re: what should i do? by maxlee on Fri Jul 16, 2010 10:44 pm
i'll give him a call tomorrow then guys and speek to my old man for a loan till i sell my novaginny :lol: if thats the case with the engine
thank you all 8)
maxlee
Re: what should i do? by furball on Sat Jul 17, 2010 2:53 pm
Don't forget to casually mention that you've been getting advice off FOG during your negotiations. It probably won't work as well as turning up in a FOG fleece/t-shirt, but it might help if he realises you have more than a vague idea what it's worth :wink:
furball
Re: what should i do? by fogman on Sat Jul 17, 2010 4:26 pm
p reg ? ? ? are you sure its a 2.8 and not a 2.5 ? :|
Re: what should i do? by BadBoy on Sat Jul 17, 2010 4:29 pm
Re: what should i do? by gregster on Sat Jul 17, 2010 4:39 pm
Re: what should i do? by maxlee on Sat Jul 17, 2010 7:07 pm
thanks guys well update is
i called him 2day and explaned i all readyhave one and and iam just being gready wanting onther toy so really i can only pay £400 for it so if he don't sell it my offer is there phoned me up. so picking it up monday : 8)
maxlee
Re: what should i do? by furball on Sat Jul 17, 2010 7:23 pm
Well done you 8) :clap:
furball
Re: what should i do? by Drift on Sun Jul 18, 2010 12:44 am
Ha ha fantastic :dance: welcome to the 2.8 8)
I am sure we can get the niggles sorted :D
Re: what should i do? by maxlee on Mon Jul 19, 2010 8:51 pm
picked it up tonight 8)
the judder isn't all that bad and goes away when not under load so going to have a look at the back diff and prop am i right in thinking the back diff is ajustable to take the play up?
problems we found on the way home was tracking (needs a tyre ) and could feel it pull play in the steering (remembering its covered 200k) and the passanger window only goes down (needs a new switch)
i'll chuck some pics up tomorrow to show you all i thought it would have some sort of kick to it but just plods along quite happy :lol:
so far liking the frontracker / posh transit alot :party:
thanks for all the help guys and advice :D
maxlee
Re: what should i do? by Road Hog on Mon Jul 19, 2010 9:36 pm
The rear diff is not adjustable without specialist tools & knowledge :( but it will most likely be a dry/worn UJ
