Can anybody advise what metal drill bits are the best to buy for the home DIY hand held electric drill applications.
When it comes to having to drill out snapped off bolts, it always seems to be the same old story. Buy the metal drill bits from B&Q/motor factors, start drilling OK, then the drill bits seem to go blunt, guess it's the heat build up, and it takes ages to get even small bore bolts drilled out. Just wondering if there is a better quality drill bit available out there that would be worth buying in the first place.
