Frontera Technical Support • View topic - VW Passat brake help Please
VW Passat brake help Please by Alfie on Tue May 11, 2010 8:49 am
Calling all mechanics,
I am after info on brake pad changing on a VW passat 56 plate tdi 170. Is there anything I should know before we start?
Cheers Alfie
Vehicle Name: Dino
Re: VW Passat brake help Please by Sir-Doris on Tue May 11, 2010 11:24 am
Similar setup to the frontera front and rear Although your model may be big allen bolts for the sliders rather the hex head.
Re: VW Passat brake help Please by adyclemo on Tue May 11, 2010 5:16 pm
Nope they are easy peasy
Regards Ady
Comment on the motor here
adyclemo
Full lenght roof rack.
Front tow bar.
CB.
Manual locking hubs.
Suspension lift.
32" BFG's
Snorkle.
Egr delete
Re: VW Passat brake help Please by Alfie on Tue May 11, 2010 8:47 pm
Cheers Guys :D :D
Vehicle Name: Dino
Re: VW Passat brake help Please by Sir-Doris on Fri May 21, 2010 10:33 pm
Fronts should be a 7mm allen bolt for the slider I discovered yesterday ;-)
Re: VW Passat brake help Please by Alfie on Sat May 22, 2010 7:33 pm
Did the fronts,rears still to do. Need to get the correct wind back tool adaptor.
Vehicle Name: Dino
Re: VW Passat brake help Please by Sir-Doris on Tue May 25, 2010 12:20 am
No you dont :!:
Needle nosed pliers fit the V grooves perfectly ;-)
Or alternatively something like THIS Although this one is a bit expensive, but the 2 pegs are designed to fit into the grooves.
Re: VW Passat brake help Please by Alfie on Tue May 25, 2010 6:55 pm
My mates has three grooves not two. Will get it sorted this weekend :D
Vehicle Name: Dino
Re: VW Passat brake help Please by Sir-Doris on Mon Jun 07, 2010 11:35 pm
Re: VW Passat brake help Please by Alfie on Tue Jun 08, 2010 7:17 am
I have been onto sealy direct and they have a three pin tool in developement at the moment so there must be a call for them. VW issue one to their own sevice centres but there is not one available to buy yet. I will make one in the near future when my wrists are a bit better and i can opperate the milling machine :D
Vehicle Name: Dino
Re: VW Passat brake help Please by bigdazz on Tue Jun 08, 2010 10:14 am
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: VW Passat brake help Please by Sir-Doris on Tue Jun 08, 2010 1:21 pm
I still reckon needle nosed pliers will work as they shouldnt be that stiff when winding them back in. Particularly on a later model.
Re: VW Passat brake help Please by bigdazz on Tue Jun 08, 2010 1:54 pm
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: VW Passat brake help Please by BUMPTJ on Tue Jun 08, 2010 4:25 pm
Later model vw's audi's and mercs rear calipers are controlled by the ecu. You need to plug in via the obd port and then the ecu will wind the caliper back. Its all to de with the electronic parking brake.
BUMPTJ
The Parts Man
Re: VW Passat brake help Please by bigdazz on Tue Jun 08, 2010 5:28 pm
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: VW Passat brake help Please by Alfie on Wed Jun 09, 2010 7:31 am
I'll get him to stick it in the garage then if they cant be wound back manually.
Vehicle Name: Dino
