Quick urgent question
Quick urgent question by rossco on Sat May 01, 2010 8:41 am
Hi, sorry for posting this here as well but I need an answer quickly, in my new frontera someone has cut both rear seatbelts out so I need to know if sport A rear belts fit into a sport B ?
Thanks ,Ross
rossco
Re: Quick urgent question by gregster on Sat May 01, 2010 8:59 am
Not sure mate...but there is probably a fair chance that they might, if you change both parts....the mountings into the shell etc tend to fairly standard for seatbelts I have found in the past...
Best bet is have a look in local breakers if they have one, and maybe see if it will plug into your clip....
Or post some pickies up of yours and will have a look and see if they look the same as my sport...
Failing that knock on someones door who lives local to you who has an A and ask if they mind you having a quick look....pointing them in the direction of FOG as well!!!
Not much help I know, but I help this helps a bit...
Laters
Greg
Re: Quick urgent question by tabetha on Sun May 02, 2010 4:00 pm
Would be worth a look on SECURON's website as that lists about anything you could think of seat belt wise, as that's all they make.
tabetha
tabetha
