need help on Peugeot 206
need help on Peugeot 206 by andysd1 on Sat Apr 17, 2010 1:13 am
ok guys and girls, when you accelerate a bit aggressively, it pulls to the right, also it is ever so twitchy at speed, you change lanes and it moves as if it has just changed tracks
Re: need help on Peugeot 206 by gregster on Sat Apr 17, 2010 8:48 am
I suspect the lower wishbone bushes are worn...my mk5 escort diesel van did exactly the same thing and I guess ya pug has a similar suspension setup...
Wishbone bushes when worn allow one wheel to drag forwards and hence turn slightly under acceleration and then return to normal place when throttle is eased off...
Unfortunately tracking checks wont reveal the problem, will read fine, unless you can find a brave mechanic who will check it when you are a full throttle! :shock:
Hope this helps matey...
Re: need help on Peugeot 206 by Drift on Sat Apr 17, 2010 9:32 am
Sounds like torque steer, are you tyre pressures ok?
Re: need help on Peugeot 206 by andysd1 on Sat Apr 17, 2010 10:27 am
tyres are fine, just passed its mot, and i asked him to be harsh, as he is a mate,
Re: need help on Peugeot 206 by Rifleman on Sat Apr 17, 2010 10:34 am
Yup I would agree with Greg on this. Check the joints carefully.
BTW, getting your steering geometry done would be a good idea after the repair, not just the tracking. But anyone doing this SHOULD be checking the steering and suspension first, before setting up the gear for the readings.
If they dont, it would be like fitting a propshaft to a gearbox that had no gears in it. Pointless.
Re: need help on Peugeot 206 by Livewire Frontera on Sat Apr 17, 2010 12:38 pm
Totally agreed check the bushes and the are itself one too many times can bugger a wishbone over time and they just don't build em like they used to mate :wink:
Livewire Frontera
Re: need help on Peugeot 206 by damrabbit on Sat Apr 17, 2010 4:22 pm
it is most likely the wishbones i had a 206 and it was subject to a recall due to a wishbone bush problem yours may have slipped the net, mine was an 03 plate not sure which years it affected
,32mm wheel spacers
1997 BMW 328i Touring(DEAD)
1993 gas guzzling monster ?
Re: need help on Peugeot 206 by Livewire Frontera on Sat Apr 17, 2010 4:29 pm
Check the VOSA recalls website should come up there :wink:
http://www.vosa.gov.uk/vosa/apps/recalls/default.asp
Livewire Frontera
Re: need help on Peugeot 206 by damrabbit on Sat Apr 17, 2010 4:41 pm
found this on vosa website
There is a possibility that the front stub axle lower ball joint fixing may have been incorrectly machined which may result in separation of the stub axle from the ball joint/lower suspension arm.
http://www.vosa.gov.uk/vosa/apps/recalls/searches/expand.asp?uniqueID=35DBE0F0D008C9F080256BB900268A1F&freeText=Blank&tx=
,32mm wheel spacers
