I always do all the work on my cars myself....but.....
Seeing as i'm just recovering from the swine flu,and didn't fancy working on my car in these cold temperatures and dark nights, i decided to book my Fronty in to a local Garage to have the front offside wheel bearing replaced.
I left the car with them first thing and collected after i had finished work.
On arriving i was greeted by the mechanic (AND AT THIS POINT I USE THAT WORD LOOSELY) who thrust one of my locking wheel nuts in my face.
Well, actually it was my locking wheel nut with a bolt welded to it.
He then complained that my locking wheel nut key/socket was worn and that i should arrange to get a replacement from Vauxhall.
I've never had a problem with any of the lock nuts in the past and the key still fits all the remaining locking wheel nuts no problems.
Anyhew...i agreed to pay the extra £20 he charged me for removing that wheel nut just to keep the peace.
I luckily had all four original wheel nuts unused in my tool box, so replaced the lock nuts with normal nuts.
I payed the bill and drove home. On the way home a grouching/scuffing noise revealed it's ugly head and it appeared to be eminating from the same hub they replaced the bearing in.
I decided to remove the wheel from the offending hub and have a gander.
First thing i noticed was that the small gaiters on the sliding caliper pins had not been relocated properly over the pins.
This could have led to a big problem a few months down the line.
I removed the caliper to check if there was anything amiss but couldn't find any other problems.
The grouching noise is still there and only happens now and again but it really sounds like they have either damaged the bearing on assembly, not greased it, or overtightened it.
Either way....Monday morning it's going back to the garage and i'm going to give them what for.
I'll keep you updated.
AND YES....I SHOULD HAVE KNOWN BETTER.
just noticed is a B series no six bolts
