Frontera Technical Support • View topic - Wooshing Noise???
Wooshing Noise???
Wooshing Noise??? by timetraveler on Wed Feb 10, 2010 10:08 pm
When i start my truck from cold i hear a wooshing noise a racing water going round the matrix now i have noticed an occasional drop in water in the header tank an always topped it up dont think the head has gone as the usual tell tale signs are not present also it takes ages to get warm even then its luke warm any ideas on this guys??
Thanks
timetraveler
Vehicle Name: Black Beastie
Re: Wooshing Noise??? by damrabbit on Wed Feb 10, 2010 10:20 pm
i had similar symptoms and it was the heater matrix check for dampness in the carpets
,32mm wheel spacers
1997 BMW 328i Touring(DEAD)
1993 gas guzzling monster ?
Re: Wooshing Noise??? by Rifleman on Wed Feb 10, 2010 11:27 pm
could be the thermostat is stuck open.
Re: Wooshing Noise??? by furball on Wed Feb 10, 2010 11:31 pm
I get that too. Less since I flushed it, but the heater still doesn't get really really hot, even though the pipes going in and out are almost untouchably hot.
I think I have an airlock that won't go away :(
furball
Re: Wooshing Noise??? by Krusher on Wed Feb 10, 2010 11:39 pm
Furball, sounds like you still got a block...
Timetraveller, I think Keith may have a point with the thermostat...
Re: Wooshing Noise??? by furball on Wed Feb 10, 2010 11:43 pm
furball
Re: Wooshing Noise??? by Krusher on Wed Feb 10, 2010 11:53 pm
Re: Wooshing Noise??? by Drift on Wed Feb 10, 2010 11:56 pm
Well there has to be one down side to a 2.8, I wear my down North Face in it 8)
Re: Wooshing Noise??? by Krusher on Wed Feb 10, 2010 11:59 pm
Re: Wooshing Noise??? by timetraveler on Thu Feb 11, 2010 1:42 am
Will have to check the carpets me thinks :shock: i take it the woosh is an airlock? with the thermostat wide open? when i put me foot down the temp goes to just above halfway then settles down to half if not below when cruising but still not that hot takes ages to clear windows when cold my mates laguna heats up quicker lol and thats an old one :axe: and like you furball i have flushed and filled the system with new blue stuff but to no affect
timetraveler
Re: Wooshing Noise??? by MrWolf on Thu Feb 11, 2010 2:28 pm
In my 2.8 the heater is working OK. It gives enough heat at max - at least down to minus 15 degrees outside temp. Any significantly below that and the cabin gets cold. The needle on my temp gauge always comes to rest steadily at the lower quarter mark.
I'm more worried about how little air I get through the vents... Is it normal that I get just barely noticeable draft through the vents when running the fan at max and all air towards the windscreen?... :?:
MrWolf
Re: Wooshing Noise??? by fogman on Thu Feb 11, 2010 6:48 pm
with the engine running [ try & do this on start up when everythings as cool as possible, tease the supply hose off the matrix pipe so it is just about on the pipe then gently tease the hose off a little bit more so the top edge is just clear of the matrix pipe allowing any air can escape which you can clearly see & hear, when the bubbles stop coming out & the coolant flows instead replace hose back on & clip up again, then do the same with the return hose, place a small bucket under both pipes/ hoses so you can catch any lost coolant & with a bit luck any air should now of been cleared :wink:
Re: Wooshing Noise??? by furball on Thu Feb 11, 2010 9:38 pm
furball
Re: Wooshing Noise??? by Rifleman on Thu Feb 11, 2010 9:45 pm
Re: Wooshing Noise??? by MrWolf on Thu Feb 11, 2010 10:46 pm
Thanks, I'll have a go at sorting out the ducting. The fan runs allright, but there is very little air coming ut through the vents. Very strange, I have never had a car with that little blower capacity. But I know the previous owner had the dashboard out once, so there might be some pieces misplaced in there.... I see that there are screws and nuts missing some places and that is usually not a sign of good workmanship... :roll:
MrWolf
Re: Wooshing Noise??? by Rifleman on Thu Feb 11, 2010 10:51 pm
He probably hasnt refitted some of the ducts back in place mate. Seen it myself before.
I hope its that easy for your sake.
Re: Wooshing Noise??? by Sir-Doris on Fri Feb 12, 2010 2:09 am
On a side note. There is an article in TIS relating to poor heating in the 92' to 96' model Frontera. It states that in case of customer complaint a revised/redesigned heater matrix is to be installed.
Il bet that 99% of Frontera's never had the matrix replaced as people just thought that was how it was 'meant to be'.
Reason: Model years amended
Re: Wooshing Noise??? by furball on Fri Feb 12, 2010 11:33 pm
furball
Re: Wooshing Noise??? by Sir-Doris on Fri Feb 12, 2010 11:46 pm
Re: Wooshing Noise??? by timetraveler on Sat Feb 13, 2010 2:08 pm
Possible vehicle recall???? that was not done to some trucks???
timetraveler
Users browsing this forum: No registered users and 76 guests
