Frontera Technical Support • View topic - FIAT PUNTO 1.2 8V 04 MISFIRE
FIAT PUNTO 1.2 8V 04 MISFIRE by FRONTY 4 X 4 on Wed Jan 20, 2010 9:53 pm
ITS RUNNING ON ALL 4 BUT IT HAS A MISFIRE @ ANY REVS
AS ANYONE GOT ANY IDEA OTHERWISE ITS GOING TO GET THE SCRAP YARD TREATMENT :(
CODE READER READS MULTIPLE MISFIRE P0300 OR P300
ANY IDEA WILL BE A GREAT HELP
REGARDS
DARREN
REGARDS
DARREN
VAUXHALL FRONTERA
2.2 LIMITED LWB
NOV 2000
( X )
Y22SE
STAR SILVER 2
VECTRA C 2004
FIAT DUCATO 2 2006
FRONTY 4 X 4
Vehicle Name: ARETNORF
FRONT TOW BAR
NUDGE BAR
CRUISE LIGHTS
UPRATED CLUTCH
4 NEW COOPER DISCOVERER TYRES
TINTED WINDOWS
H.I.D HEADLIGHT KIT 8000K
Re: FIAT PUNTO 1.2 8V 04 MISFIRE by Road Hog on Wed Jan 20, 2010 10:05 pm
Hi Darren,From P0300,I get.......
Random/multiple cylinder(s) - misfire detected
Probable causes............ Spark plug(s), HT lead(s), injector(s), ignition coil(s),low compression, wiring
Hope that helps a bit :wink:
EDIT: turn your CAPS lock off please bud
Re: FIAT PUNTO 1.2 8V 04 MISFIRE by mad mechanic on Wed Jan 20, 2010 11:17 pm
coil packs are prone on these mate, check the wiring plug for oil contamination too. will read ok on the bench but when under load they break down.
hth andy
mad mechanic
Re: FIAT PUNTO 1.2 8V 04 MISFIRE by FRONTY 4 X 4 on Thu Jan 21, 2010 12:24 am
REGARDS
DARREN
VAUXHALL FRONTERA
2.2 LIMITED LWB
NOV 2000
( X )
Y22SE
STAR SILVER 2
VECTRA C 2004
FIAT DUCATO 2 2006
FRONTY 4 X 4
FRONT TOW BAR
NUDGE BAR
CRUISE LIGHTS
UPRATED CLUTCH
TINTED WINDOWS
Re: FIAT PUNTO 1.2 8V 04 MISFIRE by furio on Thu Jan 21, 2010 3:27 pm
Had a 51plate Bravo mate with this and was found to be the HT leads. Glad you got it sorted bud :wink:
furio
Manual Cooling Fan Switch
Old Man Emu Suspension lift
Roof lights
Raised Axle Breathers
