Frontera Technical Support • View topic - Battery clamp
Battery clamp
Battery clamp by vargas on Sun Jan 17, 2010 10:08 pm
Can anyone confirm if this will fit a 95 swb 2.0 petrol?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0396204369
Many thanks
Kev.
vargas
Modifications: Falken Landair/AT 31/10.5/15
Midland 98 plus CB
2" coil lift
Uprated recovery points front + rear
Re: Battery clamp by Sir-Doris on Sun Jan 17, 2010 10:26 pm
Should do. Battery location and mounts are the same across the A series range.
Re: Battery clamp by john (smifffy) on Sun Jan 17, 2010 10:31 pm
mine has a hook on the bottom of each rod and there is a bit on the top that hooks on to the bit on the inner wing
Re: Battery clamp by robbie on Sun Jan 17, 2010 11:12 pm
the 1 that is on my m reg is simaler to that 1 but is hooked on both ends of the threaded bar with nuts on the top and the 2.5 R reg is the same as smifffys. I wud say look at the battery tray and see if there is a tab on the inner and outter side of it with a hole 2 hook through or take a pic and post it so ppl can compare it to there own . Hope this is of help
rpbbie
robbie
Vehicle Name: The white 1
Modifications: 2.5 the white1
2.0 1997 the gold1.
2.0 1997 green1.
Re: Battery clamp by Drift on Mon Jan 18, 2010 12:03 am
Also the bar across the top should be straight and not bent at the ends where the nuts are, both mine have hooks on the two bars not threaded, thats not of a late A series in that picture.
Re: Battery clamp by 4x4 bobby on Mon Jan 18, 2010 12:18 am
Straight answer is no it wont fit !!!!
Re: Battery clamp by vargas on Mon Jan 18, 2010 6:48 pm
vargas
Midland 98 plus CB
2" coil lift
Re: Battery clamp by tom on Mon Jan 18, 2010 7:20 pm
tom
Re: Battery clamp by vargas on Mon Jan 18, 2010 7:27 pm
vargas
Midland 98 plus CB
2" coil lift
Re: Battery clamp by tom on Tue Jan 19, 2010 4:52 pm
tom
Re: Battery clamp by vargas on Tue Jan 19, 2010 8:47 pm
How much?
vargas
Midland 98 plus CB
2" coil lift
Users browsing this forum: No registered users and 75 guests
