Cooling system flushing
Cooling system flushing by magoogriff on Sat Jan 16, 2010 12:58 pm
Get this one!
At my local garage they were going to flush out the water system on a car so they drained the system a bit and proceeded to stuff a quarter of a packet of cheap clothes washing powder ( co-op non bio) into the expansion tank filler hole!! On enquiry it seems this is a crackin way of flushing out the entire cooling system withour using harmful/caustic products. After getting the egnine warm and running it fir a bit the result was amazing!!The rubbish that came out on draining the radiator was mad-even better results if you leave it for a few days normal use.They do it all the time now!!
Anyone else heard of this one??
Magoo
magoogriff
Re: Cooling system flushing by Drift on Sat Jan 16, 2010 1:02 pm
:shock: cant say Ive heard of that, good old back flushing for me I think using a hose pipe should give the same results.
Re: Cooling system flushing by drinksoptional on Sat Jan 16, 2010 1:49 pm
i use the old hose pipe too dodgy pratice that using soap powder it has the tendancy to turn into a gooey mess when cold blocking pipes it did to my washing machine when the hot pipe buggered up
Re: Cooling system flushing by john (smifffy) on Sat Jan 16, 2010 2:02 pm
i used the stuff that you use for descaling a kettle put it in and leave for a few days then drain and flush
as anything that that descales will tend to leave a deposit build up in rad or heater matrix
so its easier to just flush back through
Re: Cooling system flushing by john boy on Sat Jan 16, 2010 2:29 pm
Yeah does work i've used it before :wink: going do it on the mrs's freelander when it's done :!:
Re: Cooling system flushing by mystic fred on Tue Jan 19, 2010 2:55 pm
which one washes whiter..? :D
mystic fred
Users browsing this forum: No registered users and 76 guests
