4x4 fault
4x4 fault by andysport on Sun Jan 10, 2010 10:41 pm
can anyone please advise me? I have the 2.2 petrol S reg: When i press the button on the dash to select 4wd the green light on the dash flashes all of the time and during this I can select between 4 high and 4 low with the leaver but 4wd dosent engage can anyone advise on this
Many thanks
andysport
Re: 4x4 fault by andysd1 on Sun Jan 10, 2010 11:17 pm
think this might be down to oil, check the transfer case, and there was another place to check,
cue A friend,
he put something up the other day, will have a look for it and post back,
Re: 4x4 fault by Drift on Sun Jan 10, 2010 11:19 pm
Check gear box oil and all associated vacuum pipes as the ends can split and leak.
Re: 4x4 fault by vaux_2 on Sun Jan 10, 2010 11:40 pm
I think this is the one you're looking for ;)
http://www.fronteraowners.co.uk/forums/viewtopic.php?f=6&t=30698
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
vaux_2
Modifications: ~
Calmini +3" lift c/w new trailing arms & upper control arms
+1.5" Bodylift
tti TCB 880 CB with sirio Hi power antennae c/w speaker under the bonnet
285/75/16 Insa Turbo Special Tracks on black modular
Pipercross Viper Induction Kit
Airflow snorkel
Roof lights
HID Headlights with LED sidelights
Powerflow full St/st Exhaust System with st/st downpipe off manifold
Re: 4x4 fault by andysd1 on Mon Jan 11, 2010 12:48 am
thats the one, cheers
Re: 4x4 fault by andysport on Tue Jan 12, 2010 5:23 pm
Thanks to all I will look into it when the snow goses
andysport
Users browsing this forum: No registered users and 86 guests
