Frontera Technical Support • View topic - Little bit of help in Birmingham
Little bit of help in Birmingham by crabman on Sat Jan 09, 2010 1:25 pm
Before I call in a mobile mechanic , does anyone local to Selly Park area south Birmingham , have a multi-meter thingy and know how to use it ?
Fronty failed to start today , engine not turning over , battery gauge goes up to first mark and dips when ignition turned all the way , not missed a beat up till now in this weather .(battery was new this time last year)
According to the Haynes manual this may indicate starter motor failure ?
Apologies if this is in the wrong area .
Typically I was just getting ready to type up a little report to add to my members rides thread ,on my first year of Fronty ownership , and how cheap and fun the years motoring had been , doh .
''Too bad it didn't thunder when you said that. That would have been cool. Like you're an evil genius or something.''
My wagon viewtopic.php?f=46&t=23335
Comments on my wagon viewtopic.php?f=32&t=27552
crabman
Vehicle Name: Lars , you need not fear me .
Modifications: General Grabber AT2 255 65 16 AT tyres fitted to 16x8 black modular wheels , standard Tokico shocks and replacement springs(+20%) , front adjusted to match, Sidesteps removed , rear light guards removed , spare wheel holder removed , bullbar removed , badges and stickers removed .
Re: Little bit of help in Birmingham by Alfie on Sat Jan 09, 2010 1:36 pm
Possible stuck starter motor, duff alternator not charging or a dead battery caused by the cold.I suspect a dead battery. Take it off, charge it up or try a jump start from another car.Heavy snow here at the moment. So not going out to play.............. too cold.Pm me if that doesnt work.
Vehicle Name: Dino
Re: Little bit of help in Birmingham by john (smifffy) on Sat Jan 09, 2010 1:38 pm
have you tied getting a jump start as cold might of killed battery :?:
i went out to a corsa 3 months old and battery was dead used power pack and it started straight away
Re: Little bit of help in Birmingham by crabman on Sat Jan 09, 2010 3:14 pm
Thanks for the replies , will have to wait till to tommorrow now , just taking a deep breath and a step back for the moment , will try a jump start tommorrow , hopefully just a battery issue as the way the weather forecast looks I will need The fronty Monday to make sure my Daughter gets to her Exams .
crabman
Re: Little bit of help in Birmingham by jason on Sat Jan 09, 2010 4:03 pm
Hi
It sound like the starter motor has gone, you can get it repaired, i have just had mine done cost £40 to have it done chap in soilhull dose them
If your battery has gone you should still have warranty on it if you brought it this time last year.
I doubt its the alternator as you would no when driving it
JAY
Re: Little bit of help in Birmingham by bigdazz on Sat Jan 09, 2010 4:53 pm
sound like starter motor problem hit it with a hammer a few times[ recon for about 35 ,40 pounds ]
battery might be flat due to cold try a jump start if it does not turn over or you get a clicking nose its your starter my friend
also check earth going to starter to make sure its on tight
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: Little bit of help in Birmingham by crabman on Sun Jan 10, 2010 2:53 pm
All is well in the world , managed to jump start the Fronty , replaced the battery , so at least its not the starter motor , how can I test whether the alternator is working ? If I purchase a multi-meter could someone talk me through how to use one ?
crabman
Re: Little bit of help in Birmingham by john (smifffy) on Sun Jan 10, 2010 3:00 pm
Re: Little bit of help in Birmingham by Drift on Sun Jan 10, 2010 3:01 pm
Even Halfords will do a free battery check :wink:
Re: Little bit of help in Birmingham by jason on Sun Jan 10, 2010 3:05 pm
Well done mate
I got one off these easy to use http://cgi.ebay.co.uk/12v-Battery-Alter ... 3ca7495e80
I have also have multimeter but its a bit to technical for me :lol:
Re: Little bit of help in Birmingham by bigdazz on Sun Jan 10, 2010 4:32 pm
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Users browsing this forum: No registered users and 86 guests
