Clutch Biting Point
Clutch Biting Point by vargas on Wed Dec 30, 2009 7:08 pm
Hi all, looking to buy my first fronty and have read a for sale thread (SWB 1995) but my concern is that the seller says that the biting point is low but doesnt slip. Is this a concern for me?
Kev.
vargas
Modifications: Falken Landair/AT 31/10.5/15
Midland 98 plus CB
2" coil lift
Uprated recovery points front + rear
Re: Clutch Biting Point by jcv1968 on Wed Dec 30, 2009 7:16 pm
Only if you dont mind changing the clutch, expect anythin up to £300.
My other Frontera is a Frontera. My Corsa is a baby Frontera.
jcv1968
Vehicle Name: Freddy
Modifications: Refitted a propper vauxhall radio!
Rebuilt engine, fast road cams, new injectors, Lamda sensor, Crank sensor.
Re: Clutch Biting Point by vargas on Wed Dec 30, 2009 7:23 pm
So as the clutch wears the biting point on the pedal will get closer to the floor?
vargas
Midland 98 plus CB
2" coil lift
Re: Clutch Biting Point by Sir-Doris on Wed Dec 30, 2009 7:45 pm
Just had the clutch replaced on mine and the bite point is quite low. It should be higher up as the clutch wears. Its possible it has a cracked bulkhead or a leaky master/slave cylinder or it might just need bleeding.
Check the clutch fluid level, if low it may be due to a leak, if it is brown and gunky looking it may be past the end of its useful life and will need replacing.
Check the area the pedal bolts to for splits/cracks. Fix is to weld.
If master cylinder is leaking the area where the pushrod comes through the bulkhead inside the car may have fluid weeping out. Repair kits are available cheaply from VX.
Dont think slave cylinder repair kits are available any more but a good used part will work just as well.
Re: Clutch Biting Point by vargas on Wed Dec 30, 2009 7:58 pm
Lovely thanks for the info :D
vargas
Midland 98 plus CB
2" coil lift
Users browsing this forum: No registered users and 85 guests
