Frontera Technical Support • View topic - exhaust manifold
exhaust manifold
exhaust manifold by owain on Tue Dec 29, 2009 10:08 pm
what sort of noise would a cracked manifold do? would it be like a taping sound but not a metalicy taping sound?
owain
Modifications: Tinted rear windows
Re: exhaust manifold by jcv1968 on Tue Dec 29, 2009 10:36 pm
That sounds about right. Remove manifold heat sheild and the crack should be pretty evident.
It would help if you put more info on your profile about your vehicle, it helps chaps (and chappettes) diagnose problems more easily.
My other Frontera is a Frontera. My Corsa is a baby Frontera.
jcv1968
Vehicle Name: Freddy
Modifications: Refitted a propper vauxhall radio!
Rebuilt engine, fast road cams, new injectors, Lamda sensor, Crank sensor.
Re: exhaust manifold by owain on Wed Dec 30, 2009 10:20 am
sorry, its a 1995 2.4 petrol,lwb,
gfreat so thats two jobs with the welder allredy, iv only had it a week lol, thanks
owain
Re: exhaust manifold by weave67 on Wed Dec 30, 2009 10:22 am
it may be just loose mate :wink:
Re: exhaust manifold by owain on Wed Dec 30, 2009 12:56 pm
id hope so, itd make things esier, do i need to remove the inlet manifold to get to it?
owain
Re: exhaust manifold by weave67 on Wed Dec 30, 2009 1:08 pm
no i dont think so, its all on the same side :D and uses the same bolts
Re: exhaust manifold by Sir-Doris on Wed Dec 30, 2009 2:28 pm
Re: exhaust manifold by jcv1968 on Wed Dec 30, 2009 6:55 pm
It tends to be the 2.2 exhaust manifold that cracks.
jcv1968
Re: exhaust manifold by nightowl on Thu Dec 31, 2009 8:13 pm
welcome to the club off 2.2 cracked manifolds theres lots and lots of members :lol: mine was cracked got a new on on ebay wasnt bad price the guys on here gave me the link i aint technical minded so aint got a clue how to get it on but mine been fine since fitting new one im sure some one on here can get the link up for you dont know if welding it will work
nightowl
Model: 2.2i Transglobe 5dr
Vehicle Name: big blue
Modifications: dixie airhorns (had to be done they know its me coming )
general grabber at2 tyres
standard at the moment
Re: exhaust manifold by Road Hog on Thu Dec 31, 2009 11:49 pm
Re: exhaust manifold by furball on Fri Jan 01, 2010 12:17 am
If you do end up having to take the manifold off you should be very careful trying to undo the bolts as I'm pretty sure they have a habit of snapping leaving you having to drill the rest out.
Last time I needed one doing I sent it to the garage so they would have the hassle if it happened :D
furball
Re: exhaust manifold by Road Hog on Fri Jan 01, 2010 12:58 am
Manifold gasket on Ebay just in case you need one :wink:
Re: exhaust manifold by prescott on Sun Feb 14, 2010 11:11 pm
I have got leaking manifold...2 broken studs, (2.2 v16 ecotec) evident by slight discloration of head directly above stud, also tapping noise exspecially when cold, having it fixed this week..... :( :( :(
grass is always greener on the other side
prescott
Modifications: My SPORT is pure as the driven snow, just as it came off the assembly line, now has 40,000 miles on clock and a knock in the X22SE engine. Just done a removal, dismantle and reassemble of Engine, replaced MAINS, BIG ENDS and RINGS.
Re: exhaust manifold by Drift on Sun Feb 14, 2010 11:48 pm
Sounds right Prescot as when the manifold heats up the gap closes and its a snug fit.
