Frontera Technical Support • View topic - Wheel Spacers What will they do for me.
Wheel Spacers What will they do for me. by country_Est on Tue Dec 08, 2009 4:52 pm
2000 Frontera 2.2 DTi Ltd
country_Est
Vehicle Name: panserbjørne
On a B you will need to do the A friend Hack n' Slash to the rear of the front arch to stop them from catching. A tweak on the torsion bars may help.
Spacers may or may not help here.
Spacers will widen the track of the vehicle.
In theory this should aid stability when cornering and reduce the likelihood of rolling on side slopes. Another benefit would be a reduced turning circle but I imagine this would be marginal.
Suspension may well be a little more supple as the distance from the fulcrum point has increased but again marginal.
Re: Wheel Spacers What will they do for me. by fogman on Tue Dec 08, 2009 5:37 pm
hi mate, spacers wont help you with your problem they will only push the wheels out a bit further giving you a slightl wider track
what you need is the A friend big tyres on a b series thread - viewtopic.php?f=41&t=8359&start=0&st=0&sk=t&sd=a
edit sir doris is damn quick :wink:
Re: Wheel Spacers What will they do for me. by Road Hog on Tue Dec 08, 2009 8:48 pm
:dance: :dance: 8) mentioned in two consecutive posts 8) Fame at last :dance:
The A friend ' Hack n slash is what ya want mate. :lol:
There ya go Bernie 3 posts in 1 thread :butt:
Personally i wouldn't consider fitting spacers as nearly all that i have seen are unspigoted , placing the whole weight of the vehicle on the studs .... Add to that the extra load on the wheel bearings that will eventually lead to premature failure of a new bearing , let alone one that has 90k + on it .
Grim_reaper
Vehicle Name: Goose
Modifications: Side and rear windows tinted , 265/75/16 Runaway drift tires , Stainless bullbar ,
Body repair shop in the rear , 16"Smiths alloy wheels
Users browsing this forum: No registered users and 85 guests
