Frontera Technical Support • View topic - todays post
todays post
todays post by mega-fronty on Tue Dec 01, 2009 7:55 pm
has someone nicked it rom the 2.8 section??? :shock:
Simon
Buggy drivers do it with Helmets on........
mega-fronty
Vehicle Name: Barricade
Modifications: Suzuki Vitara
200TDI engine
32" Bronco Dirt Devils
Re: todays post by Drift on Tue Dec 01, 2009 7:58 pm
? whats up Si :?
Re: todays post by Sir-Doris on Tue Dec 01, 2009 7:59 pm
Eh?
Re: todays post by mega-fronty on Tue Dec 01, 2009 8:04 pm
think ive goosed sids engine
been getting irattic temps at speeds but calms down when not being pushed
changed water but still temp likes to rise more than usuall
mega-fronty
200TDI engine
Re: todays post by Drift on Tue Dec 01, 2009 8:10 pm
Sounds like either water pump or radiator, this happened both times on mine :wink:
Your rad wont need to leak to cause this, just abused off road as I know you do, :wink: my old abused rad. :oops:
Re: todays post by mega-fronty on Tue Dec 01, 2009 8:15 pm
been ok upto this afternoon thou ste
mega-fronty
200TDI engine
Re: todays post by Drift on Tue Dec 01, 2009 8:19 pm
Still worth swapping out the rad to check, also look above the water pump and see if its leaking, mine was but wasnt dripping to the ground seemed to cause a lack of pressure, you may see a small damp patch above the pump but thats nothing to worry about.
Are you loosing coolant?
Check expansion bottle hasnt cracked around the top.
Re: todays post by mega-fronty on Tue Dec 01, 2009 8:20 pm
aah expansion bottle had pressure in it after hr standing ste :oh yer:
mega-fronty
200TDI engine
Re: todays post by Drift on Tue Dec 01, 2009 8:22 pm
Is the clutch ok on the viscous fan?
Re: todays post by mega-fronty on Tue Dec 01, 2009 8:23 pm
when i swapped coolent didnt seem to be much that came out if im honest dont no wot litreage shud be but not much feel onto the floor
si
mega-fronty
200TDI engine
Re: todays post by mega-fronty on Tue Dec 01, 2009 8:24 pm
not checked fan clutch tbh ste
mega-fronty
200TDI engine
Re: todays post by Road Hog on Tue Dec 01, 2009 8:27 pm
Bottom part of Nancy`ss rad was clogged with mud,Neil hosed it out & has been fine since :wink:
As for your original post,not a clue bud :?
Coolant capacity for 2.8 TDI is 8.8 litres :wink:
Re: todays post by Drift on Tue Dec 01, 2009 8:28 pm
Unless you empty the rad and flush the engine and matrix most water will stay in them just whats in the pipe will come out, the water will settle to the lowest points in the system its quite hard to get it all out.
Re: todays post by mega-fronty on Tue Dec 01, 2009 8:30 pm
hi bernie
no way 8ltrs came out 5 max id guess
just not sure why it started this afternoon
keep lookin @ temp now :roll:
si
mega-fronty
200TDI engine
Re: todays post by Drift on Tue Dec 01, 2009 8:31 pm
Only other cheap fix is the thermostat playing up.
by mega-fronty on Tue Dec 01, 2009 8:35 pm
only thing i can do is keep eye on it for now check coolent level and fan clutch
thanx guys
mega-fronty
200TDI engine
Re: todays post by Road Hog on Tue Dec 01, 2009 8:36 pm
Si,if it helps I will pop over later in the week when my guts get back to normal,been :sick: since Sunday lunch & don't want to spread it about :(
Re: todays post by mega-fronty on Tue Dec 01, 2009 8:40 pm
mega-fronty
200TDI engine
Re: todays post by woodwizzard on Tue Dec 01, 2009 10:42 pm
Temp sender could be on its way out.
Users browsing this forum: No registered users and 86 guests
