Frontera Technical Support • View topic - 2.0l out V6 in?
2.0l out V6 in?
2.0l out V6 in? by BillMex on Tue Dec 01, 2009 12:24 am
Hello all, has anyone found or perhaps created for themselves a list of the mods and extras required to squeeze a 3.2l V6 into a 2.0l Sport SWB?
My 97 2.0l has just blown a second head gasket in less than 10k miles so it's time to spend a significant amount of cash and it seems like a good idea to consider something a bit different. The car is used for laning, occasional trials and as the service and tow barge for a competition MG Midget so mpg is not a serious consideration whereas extra power will be welcome.
Yes I know I could just go out and buy a more suitable vehicle but I'm attached to this one and would prefer to give it a little overdue mechanical TLC and a new lease of life.
I've only recently got rid of my 2003 2.2 TDi which was much better on power but somehow lacked the character of the older car which I've now owned for around 10 years.
Any relevant thoughts, suggestions and comments will be much appreciated.
Bill
BillMex
Re: 2.0l out V6 in? by Drift on Tue Dec 01, 2009 12:43 am
My thoughts are its possible, though most things are given cash :lol:
When choosing the engine or donor car go for the non fly by wire V6 and save a lot of ECU headaches.
Re: 2.0l out V6 in? by BillMex on Tue Dec 01, 2009 2:52 pm
Thanks Drift. I'm guessing the earlier cars were not fly by wire so I'll see what I can find.
Bill
BillMex
Re: 2.0l out V6 in? by drinksoptional on Tue Dec 01, 2009 3:48 pm
What a fly by wire if you do not mind me asking :?:
Re: 2.0l out V6 in? by domino on Tue Dec 01, 2009 3:55 pm
Fly by wire: Throttle cable
Non Fly by wire: ECU Controlled :)
domino
Sleeper
Model: 2.5 TDS Transglobe 5dr
Re: 2.0l out V6 in? by Road Hog on Tue Dec 01, 2009 4:27 pm
Re: 2.0l out V6 in? by Road Hog on Tue Dec 01, 2009 4:33 pm
Is yours a leaf or coil sprung model ??
Re: 2.0l out V6 in? by domino on Tue Dec 01, 2009 4:46 pm
Bollox. Having a blond day :D :) :(
domino
Sleeper
Re: 2.0l out V6 in? by BillMex on Tue Dec 01, 2009 8:34 pm
Hi A friend, mine's coil sprung. Does that make it better or worse for the task in hand?
Bill
BillMex
Re: 2.0l out V6 in? by furio on Tue Dec 01, 2009 8:41 pm
I'm watching this thread with interest, as something that had occurred to me. Would the v6 bolt straight onto gearbox/transfer box or require some sort of adaptation? Or would you also need the gearbox and transfer box out of the donor car?
furio
Manual Cooling Fan Switch
Old Man Emu Suspension lift
Roof lights
Raised Axle Breathers
Re: 2.0l out V6 in? by Road Hog on Tue Dec 01, 2009 8:51 pm
Makes it easier to get the right diff` ratio`s ,but to get the B series rear axle in you will need to cut all the linkage mounting points off both axles & weld yours on the B,as the A is 4 point fixing & the B is 5 points.Not sure on the front though.
You will also need;
gearbox
dashboard
cabin & under-bonnet looms
ECU
radiator
exhaust system (will need shortening)
prop shafts (will probably need adjusting)
TBH.the best bet is to get a complete donor car as there will be loads of fiddly bits & having them to hand will save loads of running around :wink:
Re: 2.0l out V6 in? by Sir-Doris on Tue Dec 01, 2009 9:14 pm
diff ratio on your 2.0 will be 5.13:1
Cant say for sure what the 3.2 ratio is.
Re: 2.0l out V6 in? by Road Hog on Tue Dec 01, 2009 9:36 pm
3.2 has build variables so could .....
4.10:1
4.30:1
4.56:1
4.78:1
Re: 2.0l out V6 in? by Sir-Doris on Tue Dec 01, 2009 9:41 pm
Re: 2.0l out V6 in? by Road Hog on Tue Dec 01, 2009 10:11 pm
Users browsing this forum: No registered users and 86 guests
