Electrics
Electrics by woodwizzard on Wed Nov 25, 2009 2:12 pm
Not car related but on my woodworking bandsaw. I have 2 micro safety switches on my bandsaw, I think one or other of them may have stopped working as my saw won't switch on. Have checked fuses etc. Is it ok for me to join the micro switch wires together to by-pass them and thus eliminate them from the problem.
Re: Electrics by Road Hog on Wed Nov 25, 2009 2:40 pm
Electrically yes just join & insulate the wires,but from a safety point of view it is a big no no,the best bet would be to use a multi meter to test for resistance when the contacts are closed .Then temporarily bridge the offender :wink:
Also it may be that it has lost the magnetism in the main contactor
Re: Electrics by woodwizzard on Wed Nov 25, 2009 3:24 pm
When you say main contactor is that the main on/off switch? I was using the saw in the morning and then went to use it in the afternoon and it wouldn't switch on :?
Re: Electrics by Sparky Martin on Wed Nov 25, 2009 4:52 pm
I am an electrical safety engineer with 45 years experience, safety devices are only provided as a last result, usually because someone in the past has lost part of their body by either doing something silly (stupid or cutting corners). There intent is to remove any potential hazard from occurring. Do you have the need to retain parts of your body for future use!!
If so then get a professional competent electrical engineer to either repair it or get it replaced.
You have only one chance to get it right but many chances to get it wrong, so what I am saying is get it right first time.
Sorry about the lecture but personal safety is very close to my hart.
Sparky Martin
Modifications: None, its as good as it came of the production line.
Re: Electrics by woodwizzard on Wed Nov 25, 2009 6:16 pm
Don't worry bud, I'm very attached to my body parts and intend being buried with the same amount I was born with :lol: :wink: I'm not looking to by-pass the switches permanantly just wanted to test them. They are both fine, the problem seems to be with the on/off switch, I'll stick an old nail in it and give it a wiggle....no no, only kidding :lol:
Re: Electrics by james'll fix it on Wed Nov 25, 2009 9:16 pm
If you do look at it, take off the saw blade, its easy to forget if it starts up suddenly.
best way is with a continuity tester accross the micro switch terminals, with the power off.
james'll fix it
Modifications: +2"
repaired seat base
Re: Electrics by Road Hog on Wed Nov 25, 2009 9:23 pm
Is it a push button on/off switch Jim ?
Re: Electrics by woodwizzard on Wed Nov 25, 2009 9:51 pm
'Tis a push button, one of those typical two button numbers, red and green.
Users browsing this forum: No registered users and 86 guests
