Frontera Technical Support • View topic - OK where does it go then:- can't find the end!!!!!!
Well I am 99% complete on renewing All the vacuum pipes on my Fronty even those little suckers deep down on the near side bulkhead, :dance: :dance:
But I have now completely got stuck :shock: :shock: and that is the vac pipe that is at the end of the Auto box just before the drive shaft :shock:
Now me being me, :oops: just thought that it was just a short pieces of vac pipe that goes from one end and just ended up some where near by :oops:
However before I disconnected the pipe I just decided to follow the pipe with my fingers as to know where it did end up !!!! and all I will say is my fingers are still under there, led on me back, arm fully stretched out, Force 5 gale blowing up me trouser leg and I still could not find the end, I felt something like a "T" piece up there but still could not find the other end :oops:
So please could someone put me out of my misery and tell me where it ends up and the best way of renewing it.
Though it looks like it’s going to be another day now as the winds getting up the rain's coming down and the boats are coming into the bay for shelter!!
we can always tell how bad its going to be by the amount of boats in the bay at present we have six :sick:
hipplew
Sorry not a clue about the vac pipe, but if big suckers like that boat are sheltering its gonna be a hoolie :shock:
Not yet its only blowing 30 and gusting to 45 so it's not bad yet :D Though a "be a be prepared" :shock: has just been issued from the met office for this area :shock: so time to get the fire going and sit back and listen to those waves crashing down :lol: :lol: (and you may think I'm joking :shock: I'M NOT)
Still the house has stood for three hundred years and the wall's are two and a hlaf foot thick granet so not much gets through :lol: :lol:
Mind you you know when its realy BAD when you get one of these turning up on your door step :lol: :lol:
hipplew
Aha they are the cause of much confusion,there is nothing on the Automatic or manual gearbox that uses vacuam,although the same tubing these are in fact.......Transmission breather tubes :wink:
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
vaux_2
Modifications: ~
Calmini +3" lift c/w new trailing arms & upper control arms
+1.5" Bodylift
tti TCB 880 CB with sirio Hi power antennae c/w speaker under the bonnet
285/75/16 Insa Turbo Special Tracks on black modular
Pipercross Viper Induction Kit
Airflow snorkel
Roof lights
HID Headlights with LED sidelights
Powerflow full St/st Exhaust System with st/st downpipe off manifold
hipplew
They look good in blue 8) you have got all the under bonnet done & the chassis by the gearbox,so long as you have also done the three pipes in the front axle area,then the jobs a good `un :D
Edit:did you manage to get the one onto the vacuam pump OK,tricky little bugger that one :oh yer:
hipplew
Yep them was the three I meant :D
Will get some pics in here t`moz, it is possible just a bit of a pain,although well worth doing as we had a member with problems being caused by that very short pipe being split :wink:
