Quick Water Bottle Repair.
Quick Water Bottle Repair. by dwaned on Wed Nov 11, 2009 11:59 am
Hi All,
Just wanted to share this quick easy repair for a leaking water bottle. My bottle had a series of cracks around the top of it under the cap and the two I saw in a scrap yard where the same so I presume it must be a standard problem with them.
What I did was cover all the cracks with cotton wool, the stuff you get from a chemist or boots. Then with a fresh tube of locktight superglue soak the entire area with it and leave it to dry. Thats it! and it works! :D I only did it a couple of days ago so we'll have to see how longs it lasts but hopefully it will keep a while.
Below are a couple of photos.
Hope this helps someone.
DwaneD
dwaned
Re: Quick Water Bottle Repair. by jmc on Wed Nov 11, 2009 7:44 pm
Ingenious thanks for the post
jmc
Re: Quick Water Bottle Repair. by Drift on Wed Nov 11, 2009 8:30 pm
Very clever :D
Re: Quick Water Bottle Repair. by Sir-Doris on Thu Nov 12, 2009 2:45 am
Using cotton wool is a good idea but another method is to mix superglue with baking soda, this gives you a paste which can be used like polyfilla for cracks and gaps but with that superglue bond as superglue is not known for its gap filling properties.
Re: Quick Water Bottle Repair. by dwaned on Thu Nov 12, 2009 9:18 am
Thats why they use the cotton wool here. The fibers go into the cracks and the glue follows. Thats the theory anyway.
For the larger cracks I used a small screwdriver to push the cotton wool in and just rubbed and rolled over the smaller ones.
Lets see how long it lasts :)
DwaneD
dwaned
Re: Quick Water Bottle Repair. by john (smifffy) on Thu Nov 12, 2009 9:42 am
very good idea when it wears out a new one is about £18 from dealer
Re: Quick Water Bottle Repair. by awdriver96 on Wed Nov 18, 2009 11:34 am
Unfortunately, superglue is not waterproof. even less so with hot water ( ask any fisherman ) so it will fail I'm afraid. I would go for a new one asap, before it strands you, or worse does the engine / head gasket in when you least want it to happen.
It used to be sold as the way to join the leader to fly fishing lines, plenty of fly fishermen have lost the Trout or Salmon of a lifetime when the leader neatly slipped off the main line, not to mention the risk of drowning the fish when it gets wrapped round a stone or branch, ,its good stuff but not for everything sadly.
Mike
Frontera Lwb 2.5 tds (The powerful ! one )
awdriver96
Technical Co ordinator
Re: Quick Water Bottle Repair. by dwaned on Wed Nov 18, 2009 2:57 pm
Thanks for the info. I'll keep an eye on it. So far it's holding out but time will tell :roll:
DwaneD
dwaned
Re: Quick Water Bottle Repair. by dwaned on Fri Dec 04, 2009 6:42 pm
Super Glue Doesn't work :oops:
But it did last about 3 weeks so I suppose it's a handy fix if you where abroad and your water bottle decides to go. It should get you home.
DwaneD
dwaned
Users browsing this forum: No registered users and 86 guests
