Frontera Technical Support • View topic - Ball joint splitters from Machine Mart
Ball joint splitters from Machine Mart by paul4be on Mon Oct 26, 2009 9:29 pm
Read a few postes about lower ball joints and various splitters etc.
Just thought that I'd mention the ones I used today.
They are from Machine Mart:
http://www.machinemart.co.uk/shop/produ ... -separator
It took 2 of them, but they're cheap enough.
Thing is with these, the jaws are wider than a lot seem to be, so no need to open them out. Also, I bent one of the fork legs, but as they are not cast like a lot of the fork type, it didn't break. Just used the grinder to get it back to a usable shape.
Hope that helps somebody!!
paul4be
Re: Ball joint splitters from Machine Mart by damrabbit on Mon Oct 26, 2009 9:45 pm
cheers mate might be useful as mine are squeaking like a whores bed springs :lol:
,32mm wheel spacers
1997 BMW 328i Touring(DEAD)
1993 gas guzzling monster ?
Re: Ball joint splitters from Machine Mart by jmc on Mon Oct 26, 2009 9:54 pm
I found some useful films on (usa)youtube about ball joints.There is one where he jacks the car up jams a spanner into the resulting gap in the joint and then lowers the jack.All the force of the car goes on the ball joint which has to split. An effortless 2 minutes!
jmc
Re: Ball joint splitters from Machine Mart by horses45 on Mon Oct 26, 2009 9:58 pm
these are the ones i got the other week from thier
http://www.machinemart.co.uk/shop/produ ... tive-tools
but still to try them
Re: Ball joint splitters from Machine Mart by Drift on Mon Oct 26, 2009 11:33 pm
Re: Ball joint splitters from Machine Mart by paul4be on Tue Oct 27, 2009 12:14 am
I tried hammering the splitter in with the suspension jacked up, then dropping it, it did nothing!
Solution was the second splitter hammered in from the other side, together with a 5lb lump hammer and 18 stone swinging it!!!!
paul4be
Re: Ball joint splitters from Machine Mart by 4x4 bobby on Tue Oct 27, 2009 8:28 am
Re: Ball joint splitters from Machine Mart by Big Dave on Tue Oct 27, 2009 1:45 pm
Big Dave
_____________________________________
Fronty 94 SWB Sport 2.0i - Broke it
Little Blue Van 96 SWB Sport S 2.8TDi - Sold it
Member of http://www.northtyne4x4.com http://www.4x4uk.org
Big Dave
Vehicle Name: Honda Civic
Modifications: Dreams
Re: Ball joint splitters from Machine Mart by vaux_2 on Tue Oct 27, 2009 2:17 pm
I replaced both my upper bj's when i did my lift and the first one popped off after 3 hits with the fork, the other took 2 evenings of blood, sweat and cursing (now wishing i'd done the lower ones at the same time now :evil: but anyhoo...)
I bought some of the forged ones from machinemart, £5 each and didn't break one.
The fork managed to completly mangle the rubber boot and surrounding metal on the 2nd bj pretty bad. When i hammered the fork in it started to bend the metal lip on the stock upper arm and the arm started moving when i hit so didn't get a good shock from the hit. Tried allsorts to get it to work, heating, 2 forks, super BFOH etc. Answer was to jack up the lower arm so that when the fork was inserted on the upper bj it had good contact with the flat underside of the upperarm. Left the jack in position and hammered and it split after about a minute. If it hadn't seperated on that attempt i think i may very well have been driving around in a fronty with an allover hammerrite finish :lol:
You live and learn and that was my first experience of them, wasn't fun! Not looking forward to doing the lowers next time :(
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
vaux_2
Modifications: ~
Calmini +3" lift c/w new trailing arms & upper control arms
+1.5" Bodylift
tti TCB 880 CB with sirio Hi power antennae c/w speaker under the bonnet
285/75/16 Insa Turbo Special Tracks on black modular
Pipercross Viper Induction Kit
Airflow snorkel
Roof lights
HID Headlights with LED sidelights
Powerflow full St/st Exhaust System with st/st downpipe off manifold
Re: Ball joint splitters from Machine Mart by alex on Tue Oct 27, 2009 2:24 pm
The jack and drop technique does work at least some times. Did 2 on Fudsters car pretty easily.
