Frontera Technical Support • View topic - VW Golf
VW Golf
VW Golf by 4x4 bobby on Fri Oct 23, 2009 12:34 am
Hello people I need some help!
Ive bought a new ignition barrel for my MK3 Golf And i cant see how the old barrel comes out. any help would be appreceated.
Thank Bobster.
Re: VW Golf by leee7196 on Fri Oct 23, 2009 4:42 am
try this site me old mate,see if it looks like yours.Step by step with pics too.
http://forums.vwvortex.com/zerothread?i ... d=48295655
i forgot to say it's for mkiii golf and jetta.
leee7196
Vehicle Name: Jerry or Jeri
Modifications: 2" Body Lift....Plasma Pucks.
2" Suspension Lift.
+2" ES9000's Shocks.
FOG windscreen url front rear and side windows.
Snorkel.
Blue LED Dash Conversion.
Extended Nudge Bars.
6 spotLight roof bar.
32x11.50x15 Cooper Discovery SST Tyres.
Side Steps Removed.
Midland 78+ CB Radio.
Planned... Rock sliders OR Side steps.
New leaf springs.
Rear and side window tint.
Black Interior headlining,handles & sunvisors.
Re: VW Golf by 4x4 bobby on Fri Oct 23, 2009 5:53 am
Thanks for that Lee but its just the Barrel (lock) that i need to replace the switch is fine.
Regards Bobster.
Re: VW Golf by john (smifffy) on Fri Oct 23, 2009 8:47 am
Re: VW Golf by N1ova on Fri Oct 23, 2009 9:22 am
On my astra it was key in position two then on back of the barrel there was a little hole were you pushed a bit of old coathanger in to release the spring catch.Then pull on the key then the barrel come out
N1ova
Vehicle Name: Blue flash
Re: VW Golf by Wilberforce on Fri Oct 23, 2009 9:27 am
Essentially the same with Frontie's too... I have the locks from my old LWB somewhere, and to remove the ignition barrel, it's a case of remove cowling, insert key and turn, then depress the spring loaded pin.
Re: VW Golf by leee7196 on Fri Oct 23, 2009 8:25 pm
leee7196
2" Suspension Lift.
Snorkel.
Side Steps Removed.
New leaf springs.
Re: VW Golf by john boy on Sat Oct 24, 2009 7:09 am
If it's same as a mark 1/2 take the cowl off put the barrel against the old lock housing and look where the clips are that lock the barrel in and drill two holes in the lock housing put the key in push the clips in and pull out :wink:
Re: VW Golf by 4x4 bobby on Mon Oct 26, 2009 8:34 am
Thanks for the answers people hope its not the one you sugested Johnboy. that's too much like hard work. :lol: :lol: :lol:
