Frontera Technical Support • View topic - CB probs....
CB probs....
CB probs.... by gregster on Wed Oct 21, 2009 10:23 pm
Wotcha...
I bought a handheld CB off ebay, as thought it would be handy up the woods as often I am away from the car and cant hear the cb...
Put some batteries in it and it all lit up fine...
Thought I would check it worked ok, so took it outside to the chevy...
It transmitts fine and comes through on the chevy's cb load and clear...but it wouldnt recieve anything from the cb in the chevy!
Tried to get a rig check on the chevys one, but noone was on the air waves...to confirm it was getting out...
Was going to the workshop anyway, so took the handheld with me, tried it near the M20 and it is recieving fine!
The Cb in the truck hasnt been used for about a month, and has been untouched, other than when I unscrewed the mike and put in the glovebox the other day...
Thought that maybe its the mike...remembered Jim's midland rig is up the workshop, so I tried the mike off that to prove a point, still not transmitting..(so put jims mike back where I found it :wink: ).
The display on the Cb in truck makes out like its transmitting....but nothing being picked up on the handheld still...not even a break in the noise with no audio...
Have checked the aerial connections and they all seem ok, but they havent been touched, and the unit is recieving so I guess that must be ok...
The battery was a bit flat on the truck where it had been unused, so tried again with jumpleads on my astra (running), incase there was insufficent voltage to TX...still no joy...
Any ideas foggers??? :oh yer:
the model of the chevy's cb is a midland 38, PR27/97 if that helps????
Re: CB probs.... by Frontycustoms on Wed Oct 21, 2009 11:29 pm
Have ya got a SWR meter with the power switch on it..................if so put it on between the rig n whip as if ya was gonna SWR it in. Key the mic n see if the needle moves. My bet is the tranny has blown. Most of them have 2 in. 1 for transmit n 1 for recieve. About 3 quid to get repaired at a cb shop. :wink:
Re: CB probs.... by Wilberforce on Thu Oct 22, 2009 6:44 am
I think similar happened to my rig a while ago... Somethingin the transmit circuit let go, but was a cheap fix for a CB shop.
Greg, why don't you try using the complete rig off mine next time you're at the workshop??
Re: CB probs.... by gregster on Thu Oct 22, 2009 8:09 am
