Anyone local good at welding?
Anyone local good at welding? by N1ova on Sat Oct 17, 2009 5:15 pm
Hi there my door has been dropping and on closer inspection i think the captive nut behind the A pillar is pulling through.So i think the only solution is to weld the hinge on the pillar with the door shut.I remember this happening to my grandads fronty aswell.Is this a common problem?Would be gratefull for any advice cheers Adrian
N1ova
Vehicle Name: Blue flash
Re: Anyone local good at welding? by jmc on Sat Oct 17, 2009 8:54 pm
Not sure how you would weld the hinge on with the door shut.You may have to have it open but pushed up with a jack to thw right height to gain access to the hinge and post to weld it.
jmc
Re: Anyone local good at welding? by N1ova on Sat Oct 17, 2009 9:20 pm
Was thinking of taking the wing off.Then weld the hinge to the A pillar.Was wondering if this was a common frontera problem the nut pulling through the pillar?Cheers Adrian
N1ova
Re: Anyone local good at welding? by N1ova on Fri Oct 30, 2009 4:11 pm
Bump anyone fancy doing a bit of welding?I will pay cash or beers.Cheers Adrian
N1ova
