right guys im no expert but after researching the site i think i can explain how to do a 2" suspension lift so if your not mechanically minded like me you will be able to understand the basics
first of all to raise the front end approx 2" you wont actually need to purchase or fit anything, you simply find the torsion bar adjustment nuts which are found underneath both sides of the car, you will see them roughly at the back end of the front doors theyre stonkers 26mm i think, if theyre turned clockwise the front end will lift approx 1/4 " per complete revolution so that equates to approx 6 - 8 turns to gain the 2" front lift. plenty of wd 40 needs to be squirted on them prior to turning
i would think that this could be easier if the front wheels were jacked off the ground at the time but i have also read that it makes no difference so its a case of try & see
to raise the rear youve got 2 choices the 1st and cheapest is to fit a set of coil spring spacers like these
£30 a set from weave [ i dont think he still sells them now but you can always send him a pm ]
they are fitted by removing the rear coil springs & inserted on to the top of the springs like so in krushers picture
they are both then refitted & the rear 2" lift is complete.
the other way of gaining on the rear is to buy new set of rear coil springs but 2" longer than the standard set but theyre probably gona cost you approx £100 a pair.
i believe the standard shocks will be quite ok with a 2" height gain
