Hi All,
just a quick question, i havejust replace new head gasket and all the trimmings and car runs great. Allthough previously engine would use quite a bit of oil (approx 1 litre every 200 miles) When I replace the head gasket and seals I found that the oil seals on the valves for hammered and thought that the new ones would sort the oil consumption out.
It hasn,t changed one bit so I can only presume that it is coming up around the pistons.My colleague is very knowledgable about Frontera engines and seems to agree that this is the problem and that I should use something like Holts Piston seal. Does anyone have any experience of using this ? also my MOT due Wed so I am now panicking that it could fail if I do this after or before. Any opinions or advice would be great.
Steve
