I did think about being a real smarta4se with the surf.....
I was gonna replace the drop links with adjustable steering dampers as found on big motorbikes....
That way I could set em really stiff (and they go REALLY stiff....practically solid in fact) for road use, and just twist the dials on em when going off road which would then allow them to move freely!!!
Only had one damper at the time, and it would work, but then found a thread on a yankee yota site on how to make the other ones so did that instead!
Many race cars use the same set up to give varied antiroll bar effect for different track conditions, that is easily adjustable...
Just throwing another swerve ball for the mixing pot guys....would be really trick though!!!
